SolaraGuy.com • View topic - throttle body spacer (where to get it)
Postby TMMK Toy » Mon Jun 18, 2007 3:39 pm
Ok, so thinking about doing the throttle body spacer mod. Where do I order it from and anything special I need to be aware of when installing it?
TMMK Toy
Postby 99V6solaraSE » Mon Jun 18, 2007 3:47 pm
Midias wrote:OK I have answered this question many times so here are some copy and pastes of my answers and posts.
Fisrt off you need one from a toyota tachoma more to come from that. Second you need new screws I will be happy so send you a set of screws and washers for 10 bucks shipped. You should get it from www.hubcapsplus.com for best price about 80 bucks shipped read below.
OK here are some old threads
Posted: Tue Jun 06, 2006 12:00 pm Post subject:
OK I got it in. The Home Depot did not have 65mm m8X 1.25 bolts just 70 and 60, so in a lapse of good judgment I got 60mm The fit on the top 2 holes no washer. I will be getting 70 mm eventually. 60 mm does NOT fit the bottom 2 holes. I used the 90 mm that came with it and 2 washers each from the kit; I will probably try 70 mm later on. Other than that install was easy.
How did it feel well it is hot out today so I cannot wait for evening to really have fun but I do feel like midrange has had a nice improvement and I would recommend it as a cheap mod for other people. Second gear feels a lot nicer and the powerband feels smoother. I will try to get pictures soon.
****** Update
On the top use m8 X 1.25 70mm long and on the bottom use 2 of the 90 mm long that came with the kit and 2 washers under each 90 and 1 under each 70mm. You will need to also buy 2 m8 washers for the top sense the kit only comes with 4.
Origional Thread
http://www.solaraguy.org/viewtopic.php? ... e41509aafb
Pictures
http://www.solaraguy.org/viewtopic.php? ... tle+spacer
Redknights report of 20% ariflow increase
http://wheelskin.com/spe-34055.html
Here I found this as the cheapest place, even cheaper than the same company's ebay stuff 79.99 free shipping and enter the coupon code HELIX and get 4 dollars off
Just ordered mine they take paypal yey
I also found a couple a little cheaper on ebay but I wanted the one Greg mentioned.
99V6solaraSE
Postby TMMK Toy » Mon Jun 18, 2007 5:27 pm
Thank you. Unfortunately hubcaps plus is closed today but if I order it tomorrow should be able to get it by the end of the week. Wonder if anyone ever dynoed their ride after doing jsut this mod? Most likely not
TMMK Toy
Postby 99V6solaraSE » Mon Jun 18, 2007 5:58 pm
with just this mod i doubt it..
but if u read through one of the threads... gabe got a pretty significant amount of more air flow on the safc.
99V6solaraSE
Users browsing this forum: Google [Bot] and 51 guests
