SolaraGuy.com • View topic - Fuel Pump install, how to.
Postby Dawgz » Thu Jun 28, 2007 10:28 am
Okay so i want to change my oem fuel pump with the URD 190 walbro fuel pump
http://www.urdusa.com/product_info.php? ... =130000027
my question is, is this something i can do? or do i have to take it to a mechanic? and if i can do it, how do i go about doing this? i have no clue how to do this at all, any type of instructions would help alot.
is it easy to install? would i need anything else with the kit or is the URD kit a full kit.
Re: Fuel Pump install, how to.
Postby Paladin06Greg » Thu Jun 28, 2007 10:34 am
You can do it. It really is an easy job. Please ensure the bottom of pump itself (plastic piece) has to be shaved slightly in order for it to set down fully in your tank properly.
Easy steps:
remove your gas cap.
unhook your battery
remove the rear seat bottom
disconnect to quick disconnect fuel line
remove the retaining screws
remove the retaining plate
remove the pump
You may have to replace the electrical on you pump. The connector is provided
install the pump in the reverse to the above.
If you get hung up let me know I can walk through it with you on the phone.
Good luck.
Dawgz wrote:Okay so i want to change my oem fuel pump with the URD 190 walbro fuel pump
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Dawgz » Sat Jul 14, 2007 9:01 pm
Hey Greg, i really cant unhook the Battery, my SAFCII settings will be erased...rite?
o, and what is the procedure to undo the rear bottom seat? i dont wanna rip anything apart and break it, is it held just by clips where i just exsert some force and clips out? or is it more complicated than that?
Postby Paladin06Greg » Sat Jul 14, 2007 9:18 pm
NO, the SAFCII memory will not be erased. For the rear seat bottom just grad it at the front and pull up. It is tight but only held in by plastic clips.
Good luck.
Dawgz wrote:Hey Greg, i really cant unhook the Battery, my SAFCII settings will be erased...rite?
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Dawgz » Sat Jul 14, 2007 9:31 pm
Ur the man.
Postby DatSRBoi » Sat Jul 14, 2007 9:37 pm
Paladin06Greg wrote:NO, the SAFCII memory will not be erased. For the rear seat bottom just grad it at the front and pull up. It is tight but only held in by plastic clips.
Good luck.
Greg you forgot to mention NO SMOKING hahaha
Postby Dawgz » Sat Jul 14, 2007 9:45 pm
Good luck.
haha thanx to u as well for ur "aim" help.
Postby Astro » Sun Jul 15, 2007 9:52 am
You shouldn't waste your time with the 190lph, go for the 255lph. I found myself running extremely lean and my S-AFCII was maxed out at +50. But, that was with the Supra MAF and injectors. If you plan on doing those mods in the future, I'd reccomend it.
Either way, good luck with the install. It's pretty easy, URD makes it very straightforward. I hope you have a dremel, it makes it very easy. You'll have to cut off some plastic on the lower plastic clip holding the pump. I think you could use something else, but the dremel makes it a quick job. The other alternative is to zip tie the lower clip to hold it in place.
Postby Dawgz » Sun Jul 15, 2007 1:50 pm
im not going to 5.5 psi or higher for a while....
at what psi was urs maxed out?
Postby Astro » Sun Jul 15, 2007 2:06 pm
5.5psi
I don't know if you're thinking of using the Supra MAF, but I wouldn't. Even at 4psi, you won't be able to compensate enough fuel with that MAF and the 190 fuel pump.
Postby Dawgz » Sun Jul 15, 2007 3:28 pm
im not doing the supra MAF....or dont plan to for now.
then what?
Postby Astro » Sun Jul 15, 2007 3:33 pm
I think you're good to go. The only thing I'm doing extra is adding a return fuel line, it's pretty good insurance on not leaning out.
Postby Dawgz » Sun Jul 15, 2007 3:35 pm
and how does one do that?
Postby Astro » Sun Jul 15, 2007 3:37 pm
Check out this guy's tutorial, he's doing it on a Corolla but it's pretty much the same.
http://vamp.darkravers.net/cpg/thumbnails.php?album=142
Users browsing this forum: Google [Bot] and 53 guests
