SolaraGuy.com • View topic - Offset
Offset
Offset
Postby hari-bhari » Tue Apr 22, 2003 1:14 am
Hey guys (and gals), I'm sort of new to the forum although I already made a post in the 'For Sale' Section. I have a 2000 Solara SE I4, and I wanted to sell it and get a v6 5-spd instead. Anyways, I was wondering what exactly 'offset' means since I want bigger rims eventually (probably 18s). Thanks
hari-bhari
Re: Offset
Postby Flipside909 » Tue Apr 22, 2003 11:22 am
This should clear it up:
http://www.tirerack.com/wheels/tech/offset.htm
As for offsets on a Solara, anything +40 to +45 will do.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby happy_aggies » Tue Apr 22, 2003 11:35 am
Offset for Solara would be 35+ to 45+.
35 u gotta roll fender and 45 u may need to use spacer.
So try in between 38+ to 42+.
happy_aggies
Postby Mole » Tue Apr 22, 2003 12:00 pm
do not get anything bigger than 8.5 for width. if you do, the lower (X<+42) offset you will have to get.
Postby Guest » Tue Apr 22, 2003 8:16 pm
TRDMole177 wrote:do not get anything bigger than 8.5 for width. if you do, the lower (X<+42) offset you will have to get.
I thought 8.5 was too wide for the Solara...I thought even 8 was pushing it. I was looking at some Breyton Vision rims that are 18 X 8.5 and wanted to get them but started looking elsewhere when I realized they were 8.5.
-dbanker
Guest
