SolaraGuy.com • View topic - URD rear 02 sensor simulator
Postby TMMK Toy » Sun Jul 08, 2007 12:51 pm
Ok, so any tricks for installing one of these or is it pretty simple? I'll be ordering one hopefully monday so it'll be ready when my y pipe comes in.
Also, where do you put the black box that comes with it?
TMMK Toy
Postby Akfahad » Sun Jul 08, 2007 1:19 pm
the install is pretty easy once you find out which wires to splice. Just search and you'll find it...I'm just too lazy to remove the glove box and tell you the wires. If you still can't find out which wires they are, just post it and i'll remove my glove box. The black box is secured behind the glove box, by the ECU, by two zip ties.
Postby Dawgz » Sun Jul 08, 2007 2:44 pm
is the 02 simulator needed for the highflow cat that midas made for u, akfahad?
Postby Midias » Sun Jul 08, 2007 3:39 pm
Dawgz wrote:is the 02 simulator needed for the highflow cat that midas made for u, akfahad?
NOPE
check the tread I sent you last PM I have had it for almost 2.5 years now no CEL
Postby Akfahad » Mon Jul 09, 2007 5:10 am
in my particular case, I still threw a CEL with the high-flow cat that Midias made me. I ordered the 02 simulator before he made me the cat anyways so I could run the race pipe, so it was no big deal.
Postby Midias » Mon Jul 09, 2007 5:13 am
Akfahad wrote:in my particular case, I still threw a CEL with the high-flow cat that Midias made me. I ordered the 02 simulator before he made me the cat anyways so I could run the race pipe, so it was no big deal.
wow thats surprising I have never had that problem. Did you try the anti fowler mod.
Also sense I just found out about this I have sent this info to all that have inquired about this mod from me.
Postby Dawgz » Mon Jul 09, 2007 7:28 am
hmm, damn
Postby Midias » Mon Jul 09, 2007 7:35 am
here is a mechanical solution
ou will need a set of Spark Plug Anti-Foul's they are 18mm HELP! brand Part#42002 or 42009.
You will need to drill out a 1/2" hole in one of the Anti-Foul's
Unbolt your 2nd O2 sensor *NOT THE ONE ON THE HEADER, THE ONE ON THE Y PIPE BEHIND THE CAT*
(I would spray a little WD40 on this o2 as well before removing)
Now screw on the Anti-Foul with the 1/2" hole on top of the regular one and then screw it into the hole for the 02.
Screw the 02 into the Anti-Fouler's tighten everything up, Then disconnect the (-) Battery terminal for about 1 minute.
Postby Akfahad » Mon Jul 09, 2007 11:56 am
^^^good stuff bro...
Postby Dawgz » Sat Jul 28, 2007 10:11 pm
Midias wrote:here is a mechanical solution
that pic where the sensor is, ive never seen my pipe near all that crap, where exactly is urs located? this is the sensor AFTER the cat rite?
Postby Midias » Sun Jul 29, 2007 7:04 am
Good I am glad you have never seen it before because that pic is of a Scion Tc
