SolaraGuy.com • View topic - dogbone polyurethane bushing
Postby TMMK Toy » Sun Jul 15, 2007 1:28 am
So gonna order a stiffer polyurthane kit for my dogbone mount and I have the option of 50mm and 65mm inside diameters. What exactly will the different sizes do and which should I go with? Also, anyone ever gotten the crontrol arm kits and know which ones they recommend? Seems like differne types will give different alignment specs or something like that
TMMK Toy
Postby Dawgz » Sun Jul 15, 2007 8:19 am
where are u ordering from? id like to order one as well..
Postby SleeperSolara » Sun Jul 15, 2007 11:47 am
You should check out: http://www.globalperformanceparts.com
They have all the SuperPro bushin' you can get if they have them in stock.
For the front control arm, there are 3 diff bushin' you can order:
SPF1265K Standard caster
SPF1266K PS increased, DS standard caster
SPF1267K PS increased, DS decreased caster
For the 3 listed bushin' sets, they are for diff types of uses for your car.
I also have the dogbone bushin' kit that SuperPro released.
I'm not sure if they have 2 diff sizes for dogbone bushin' kit..... [ i coule be wrong ]
I also have Energy Suspension Rear Control Arm poly bushin', and SuperPro P/S poly bushin'.
So far i have the SuperPro dogbone poly bushin' installed, alond wit the Energy Suspension rear control arm poly bushin'.
Sittin' in my room to get installed are the SuperPro front control arm poly bushin' [standard caster], P/S poly bushin'.
I almost have all the SuperPro poly bushin' minus the RR engine mount.
Postby TMMK Toy » Sun Jul 15, 2007 12:39 pm
Ya two different sizes for the dogbone so trying to figure othe difference. So I guess only one type of bushing for the front bushing on the lower control arm and then the 3 diff types for the rear bushing on the control arms. What are the differences in the 3 and the energy suspension rearl control arm bushigns you have just the same as the super pro trailing arm kit?
TMMK Toy
Postby i20solara02i » Thu Aug 16, 2007 10:55 pm
people that have one, can you post it up
i would like take a look at it. currently looking to buy one. tried of cracking it. going for the 3rd dog bone
i20solara02i
Postby Paladin06Greg » Fri Aug 17, 2007 12:42 am
One of the first!!
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Akfahad » Fri Aug 17, 2007 5:24 am
^^^check out Greg's cardomain site, I believe he still has the pics of the dogbone since I think he was the first.
Postby SleeperSolara » Fri Aug 17, 2007 8:44 am
I think i still have mine on my cardomain also.....
Postby i20solara02i » Fri Aug 17, 2007 9:37 am
hmm.. i guess i might have to go buy one
i20solara02i
Postby Akfahad » Fri Aug 17, 2007 3:36 pm
made a big difference, as well as all the other bushings that I replaced.
that'll probably be the first thing I do to my next car.
Postby Ian » Fri Aug 17, 2007 5:35 pm
Akfahad wrote:made a big difference, as well as all the other bushings that I replaced.
In what way?
1. steering
2. Suspension
I have the dogbone on my car. I always thought about doing the steering and control arms. I think the engine mount part might require the engine to be lifted a bit, which means too expensive.
Ian
Postby Akfahad » Sat Aug 18, 2007 8:57 am
^^^both steering and suspension, hardly any roll. You can feel the difference in the steering wheel too.
Postby Paladin06Greg » Sat Aug 18, 2007 10:22 am
Steering, suspension, dogbone and aft engine mount. Solid as rock.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby SleeperSolara » Sat Aug 18, 2007 1:46 pm
Yeah i still have yet to install my P/S poly bushin's, and the front control arm bushin'....
Postby Paladin06Greg » Sat Aug 18, 2007 1:52 pm
Yep I forget I had those installed back in 2004.
SleeperSolara wrote:Yeah i still have yet to install my P/S poly bushin's, and the front control arm bushin'....
Paladin06Greg
Torqued Solara
Torqued Solara
