SolaraGuy.com • View topic - ApEXI WS EXHUAST QUESTION?????
Postby facevedo17 » Thu Jul 26, 2007 7:02 pm
Hi everyone just curious on some feedback or what would be a better muffler for me ...I have decided to go with an Apexi exhaust instead of the TRD .....and Greddy ...
Im going to be supercharged ,,, and with an custom exhaust Dats Y pipe High flow cat , just need a muffler
the two sizes available are
60mm inlet with an 105mm tip N/a
80 mm inlet with an 115mm tip Turbo
wich would be the better choice and does it depends on the amount of boost running 4 now ..plan to go up to 6psi by next year ?? please feedbacks needed thanks
facevedo17
Postby Mole » Fri Jul 27, 2007 1:53 am
no muffler.
Postby Midias » Fri Jul 27, 2007 4:14 am
if boosted go 80mm
Postby Akfahad » Fri Jul 27, 2007 6:27 am
^^^x2
Postby PhreakdOut » Fri Jul 27, 2007 7:12 am
You will notice no difference at all in performance if the rest of your exhaust is stock. The only difference will be the exhaust tone. Larger diameter inner pipes will be deeper and louder. (very slightly)
If you're not doing anything with the rest of the exhaust, just go with the cheapest.
Postby facevedo17 » Fri Jul 27, 2007 4:19 pm
Hey Akfahad in your domain page u have the Apexi exhaust aswell was that the universal or did you get the catback sytem wich are now discontinued : ( ....... do you remember the inlet and tip sizes ...
and for Midias ...just like you I see you did the Dats y pipe I have one aswell just thinking how I wanted done ... Im planning on magnaflow cat ...should I keep my stock resonator or upgrade to a bigger one along with the apexi exhaust ?? did it make a diffrence on your setup
facevedo17
Postby Midias » Fri Jul 27, 2007 4:46 pm
yes I would suggest upgrading all the piping and the resonator. It will make a difference.
Postby Akfahad » Fri Jul 27, 2007 5:42 pm
it's a cat-back, the inlet/outlet of the piping are 2.5" , don't know what the tip size is on the actual muffler tip.
Postby Jai_Jai_Binks » Sat Jul 28, 2007 1:58 pm
guy in houston that the old skool apex universal on his es, it sounded soo sweet. that made me wish i would have got that (versys my trd's...).
Postby SleeperSolara » Mon Jul 30, 2007 3:34 pm
Back when i was lookin' for exhaust for my car.
I was lookin' at the TRD, Apexi W/S and W/S II, and the Greddy Evo exhaust.
Then i picked out the Greddy Evo exhaust and i'm lovin' it. :D
