SolaraGuy.com • View topic - Jim's Torque rod installed
Postby TMMK Toy » Fri Jul 27, 2007 11:13 pm
Got it installed tonight. Hard to say for sure how much of a difference there is. Unfortuantely its been raining all evening so the road has been too slick to really try to get on it but there does seem to be less front end travel when I gun it and steering feels more connected. Also notice more vibration but not really a big deal and reallly only notice it at idle. Seems that since the front end is lifting less I'm spinning the tires more since it's wet out. Hopefully tomorrow will dry some so I can test this out further
TMMK Toy
Postby SolAraB » Fri Jul 27, 2007 11:16 pm
^^^ NICE i just installed mine a week ago.....cant really tell too much of a difference but i have to admit a couple time when i would hit instead of doing the infamous "skip" it did a clean peel.......let me know what you feel once you get to test it.....
SolAraB
Postby Dawgz » Fri Jul 27, 2007 11:16 pm
this is suppose to help u also stop that annoying "bumping" when u just floor it, and the tires just make the car bounce, power to the floor is what it gives u.
Postby SolAraB » Fri Jul 27, 2007 11:23 pm
my bad the "bumping" is what i meant when i said "skip" my car still skips a lot when i really get into it........but maybe im just launching at an rpm that is a little too high........
SolAraB
Postby Ian » Sat Jul 28, 2007 8:10 am
My launching is better and steering is more direct. I do hear the "click" noise sometimes. I'm sure it's the heim joint hitting on the the rod or bracket. I can't tighten it up any more than i have.
Maybe I'll find some polyurethane or other material to wrap around the rod and against the sides so that when the heim joint travels it won't bump against metal.
Ian
Postby TMMK Toy » Sat Jul 28, 2007 9:35 am
Ya for the sides I'm prob. gonna go with metal bushings for right now to shim it. I may see if I can find something in polyurthane that would work but def. not gonna use regular rubber. Purpose is to be stiff so dont want any give. I dont mind some feedback in the wheel as long as teh whole car doesnt rattle which it doesnt. My friend rode in in last night and said he didnt notice any change in ride quality so thats what matters to me.
TMMK Toy
Postby TMMK Toy » Sat Jul 28, 2007 2:45 pm
Heres an update. Dry roads today and yes, def. an improvement. I seem to be spinning more in second now as the power is actually trying to get to the ground now. My buddy added some shims to the rod today and seems to be a lil stiffer. I can def. push the car a bit harder in some turns as theres less front end float so I have more confidence and shifting is a lot smoother when I row the gears. Great work Jim and def. a mod worth doing!
TMMK Toy
Postby Chinky420 » Sun Jul 29, 2007 6:47 pm
hey guys, i installed mine and found that there was almost no wheel hop left in my hard launches .... and i was 'practicing' the week before to find out where the difference would be felt.
as for the heim joint space, what i ended up doing was taking the rubber grommet/spacer/thingy that was on the original mount, and then using that with the curved washer from the original mount and used that to fill the extra lateral space. there are two on the oem mount, one is a bit thicker than the other, so just check them both out until you find which fits better.
it works good, no lateral movement on the torque rod, and i've only heard one click when shifting from P to R, and that was before i figured out how to fill that extra space.
Chinky420
Lowes Special Torque Rod
Postby PASolara » Mon Jul 30, 2007 11:49 am
Check out my Lowes Special Edition Torque Rod :roll:
[Image
By pasolara, shot with KODAK V530 ZOOM DIGITAL CAMERA at 2007-07-30
PASolara
Postby Dawgz » Mon Jul 30, 2007 11:51 am
where did u get those headers?
Postby SC V6 » Mon Jul 30, 2007 11:53 am
looks like ebay headers
SC V6
Postby PASolara » Mon Jul 30, 2007 12:02 pm
Yes they are ebay headers..
PASolara
Postby Dawgz » Mon Jul 30, 2007 12:13 pm
How are they?
Postby PASolara » Mon Jul 30, 2007 12:24 pm
Not Bad after some custom work done to them. They dont have back O2 sensor hole..
PASolara
Re: Lowes Special Torque Rod
Postby SleeperSolara » Mon Jul 30, 2007 3:39 pm
PASolara wrote:Check out my Lowes Special Edition Torque Rod :roll:
[Image
Yeah that bracket that mounts on the frame of the car doesn't look very pleasin' to me. :-?
I used washers on my Torque Rod for the lateral support.
