SolaraGuy.com • View topic - Worth buying?
Worth buying?
Worth buying?
Postby Jakecallun20 » Mon Aug 13, 2007 7:33 am
http://cgi.ebay.com/ebaymotors/99-02-TO ... dZViewItem
Is this worth buying? and does it actually add 8-15 HP, if its just a SRI.
Postby Biggi_e » Mon Aug 13, 2007 7:35 am
this thread should be locked
Postby Midias » Mon Aug 13, 2007 7:45 am
USE the Search command
And NO that intake is more like negative 8 hp
Postby unbalancedwood » Mon Aug 13, 2007 7:45 am
K&N + Remove resonator...
To remove resonator....
1.Remove the LF wheel
2. Loosen the fasteners on the fender liner and peel it back to reveal a white object located in the LF bumper behind the fog light, it's about the size of a volleyball
3. It's held in by 2 bolts, just take it off and forget about it
Theres a limited amount of mods for our solaras, and half of them are knock offs and will never work as described, destroy somthing, be a waste of money.
For intakes theres TRD & K&N filters, Injen, & CP-e
As Eddie said, forget the link you posted...LOCK...
unbalancedwood
Postby Jakecallun20 » Mon Aug 13, 2007 7:54 am
Midias wrote:USE the Search command
Ok... How would I know that someone has posted this exact item? What would I search for? sorry to piss everyone off
Postby Midias » Mon Aug 13, 2007 7:59 am
I searched for ebay intake and got a lot of hits like this one
http://www.solaraguy.org/viewtopic.php? ... bay+intake
All the ebay intakes are the same pipe with a different filter and the pipe design is ALL WRONG
Postby xet » Mon Aug 13, 2007 10:18 am
I like how they say 99-02 camry's how can it fit both engines but then also not fit gen 4 camrys >.>
1998 camry xle
2005 g35 coupe 6mt
xet
