SolaraGuy.com • View topic - 38 offset with 18" 235 width tires.
Postby AChumacher » Sun Aug 19, 2007 2:57 am
i'm considering buying 18 inch rims that have an offset of 38. I'm also planning on putting 235/40/18ZR tires on them and lowering the car with Tein S Tech springs. Will they stick out too far and hit the fender?
1999 Solara SLE V6 (R.I.P.)
AChumacher
Postby bri_n_m » Mon Aug 20, 2007 1:44 pm
i think with the 235's you will rub. i assume 8" wide?
i got coilovers. no wheel gap. slightly rolled fender. 18X8 +38 on 225/40's and i rub on heavy turns/bumps. i need to get my fenders rolled more...either way you would need to roll that rear lip.
bri_n_m
Postby minchman » Mon Aug 20, 2007 3:10 pm
hi.
i have this setup. my fenders are rolled. tires WILL slightly rub on dips and bumps. i would recommend going to the 225/40/18 size.
minchman
Postby ---CAMRAZY--- » Mon Aug 20, 2007 3:27 pm
What's the width?
Postby AChumacher » Tue Aug 21, 2007 4:31 pm
the width of the tire is 8". so the best wheel tire set up for a solara is 225/40 for 18's? i don't want to roll my fenders. can someone give me a range of what offset is suggested (ie. 38-45)?
AChumacher
Postby dan99solara » Wed Aug 22, 2007 2:36 pm
225/35/18
1999 Solara V6 5spd 155k miles
TEIN springs. thats it.
dan99solara
Postby redgen1 » Wed Aug 22, 2007 5:18 pm
itll rub.
02 SLE V6
Kaizen *constant improvement*
redgen1
Postby PXLpainter » Wed Aug 22, 2007 5:24 pm
rub-a-dub-dub even on my tub! ;)
Postby Jon11582 » Wed Aug 22, 2007 5:31 pm
225/40/18 is the perfect size for that size rim on a Solara. with these tires on 18x8's at +38 (Which is actually the perfect offset for 18x8), its cutting it close, but you should not have to roll the fenders. Youll be within a couple millimeters, so even the brand of tire may affect if you rub or not.
2000 Black Solara SE
Jon11582
Postby AChumacher » Mon Sep 10, 2007 5:30 pm
thanks for all the help. i think i'm gonna use 225/40/18ZR.
AChumacher
Postby facevedo17 » Mon Sep 10, 2007 5:34 pm
I though 18x8 with an 40 offset and 225/40/18 was the perfict fit and wouln't rub ????
facevedo17
Postby Jon11582 » Mon Sep 10, 2007 6:26 pm
at 225/40/18, 38 or 40 should work in most cases.
40 is further in, and is close to the strut. Again, footprint of the tire or "lip" of the tire may affect if you rub the strut.
+35 will may rub the fender if dropped. The difference between where a +35 and a +40 sits is half a centimeter, so its not alot of room for error either way.
Jon11582
Postby Ransom8707 » Mon Sep 10, 2007 7:18 pm
I have a 225/35/19 and they only rub when the car bounces a lil I need to get my fenders rolled :(
Ransom8707
Postby r0w » Mon Sep 10, 2007 7:31 pm
i was recommended 225/40/18 from a tire shop and i wont have rubbing issues, but i don't know what he said the offset was going to be but i might be lowering so i will have to tell him my setup so i wont have issues! :S if you stay with 225/40/18 you should be good :)
r0w
