SolaraGuy.com • View topic - indiglo v.s reverse indiglo
Postby 604solara » Tue Apr 29, 2003 12:01 am
http://www.procarparts.com/store/displa ... LRAAUT-6IG
are these the gauges that glow totally blue at night? like the faces are blue at night right?? and do we have to buy the bulbs seperatly?? im really new with this car stuff so some help would be nice thanx. is the internet site above are for the blue indiglo one? cuz im lookin foh dose ones.
reverse indiglo gauges light up the numbers more instead of the faces right?
604solara
Postby happy_aggies » Tue Apr 29, 2003 7:22 am
Something like that, and no you don't need to buy extra bulbs.
Check out eBay for better pricing and model.
http://search.ebay.com/search/search.dl ... olara+glow
Just check them out and happy bidding. :D
happy_aggies
Postby alext14 » Tue Apr 29, 2003 7:47 am
yea the guages that your link is for are the ones that are totally blue at night or green. On those guages you can adjust the color. It says they are 6 different colors but what it really is is just lighter and darker tones of green and blue. And no you don't have to buy the bulbs separately, in fact these guages go right over your stock ones.
alext14
Postby RayCarlo » Tue Apr 29, 2003 8:18 am
There's also the first generation type of reverse indiglo's that are on sale on ebay, the onew where just then numbers and lines on the face of the gauge light up. I think they look better than the newer ones that are out where the middle part lights up. If you want to find them on ebay you have to do a search for "solora" gauges, not "solara".
http://search.ebay.com/search/search.dl ... sicSearch=
RayCarlo
Postby AzN_DrAgoN48 » Tue Apr 29, 2003 3:22 pm
are these hard to install yourself?
2001 Dark Blue Solara SE V6
8000k Osram HID
Silverstars fogs
Clear Corners
Passport 8500 Hardwired
Two Alpine 12" Type R Subs
JBL BP600.1
AzN_DrAgoN48
Postby alext14 » Tue Apr 29, 2003 7:12 pm
No they are pretty easy, they go over the stock ones and plug into the same outlets as the stock ones. There is a thread on here somewhere about the instalation process. All you have to do is to take out the whole console with the stock guages.
alext14
Postby krook » Tue Apr 29, 2003 9:06 pm
actually all of the aftermarket gauges aren't plug and play installation. they have a harness, but you need to 'tap' your parking lights in the back of your instrument panel and find a good ground for the other wire. i'll try and back track to the step-by-step install post....
krook
Postby 99solarai4 » Wed Apr 30, 2003 9:19 am
i believe u tap into a green wire on the far right side of the instrument cluster. maybe it was brown......i can't remember. it is definitely the far right wire though.
'99 Solara SE i-4
Back to Stock
99solarai4
Postby SpikedMantis » Wed Apr 30, 2003 10:10 am
krooked Solara wrote:i'll try and back track to the step-by-step install post....
Hey krooked, I've done the work for ya. I used your instructions when I installed mine http://www.zer0.info/solaraguy/viewtopic.php?t=1013&highlight=indiglo+install
SpikedMantis
Postby Flipside909 » Wed Apr 30, 2003 1:46 pm
Reminder, you are doing something terribly wrong if you have to remove the needles to get the guage faces on.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby krook » Wed Apr 30, 2003 2:35 pm
Flipside909 wrote:Reminder, you are doing something terribly wrong if you have to remove the needles to get the guage faces on.
correct. make sure you unplug the 3 connectors at the back of your gauge cluster to avoid confusion. the new gauges slip right over.
damn spiked mantis.. beat me to it. that's the one!
krook
Postby Guest » Thu May 01, 2003 7:19 pm
thanx pple foh all da help..and the links and sites appreciate it haha..decided to go wit da indiglo no reverse so thanx for all the help
Guest
Postby AzN_DrAgoN48 » Fri May 16, 2003 8:27 pm
do these gauges work on the solara?
8000k Osram HID
Silverstars fogs
Clear Corners
JBL BP600.1
AzN_DrAgoN48
Postby krook » Sat May 17, 2003 12:33 pm
which ones, the ones that 604solara has at the link at the top of the topic? yep, those work for our cars, but that particular model shown in the pic is only for A/T.
krook
