SolaraGuy.com • View topic - S/C INSTALLED!
S/C INSTALLED!
S/C INSTALLED!
Postby krook » Tue Apr 29, 2003 12:11 pm
okay, i FINALLY INSTALLED MY S/C!! everything is running fine. however......(uh-oh) i know there is supposed to be a slight whining noise from the s/c right?? but i keep hearing like a 'sputtering' type of noise when it's idling. it's not too loud, but it is noticible. what the hell could it be? other than that, it's boosts quite nicely! :D
FOR THOSE OF YOU CONSIDERING DOING THIS MOD YOURSELF
it's acutally not that bad. (yeah right) no...seriously, it only took me like 3 days to finish. :roll: but that was only b/c i had to keep swinging by Sears to pick up tools i didn't have. all in all, it was a great learning experience, and even if you're not too mechanically inclined (like me) this job is still a medium level DIY.
krook
Postby happy_aggies » Tue Apr 29, 2003 12:48 pm
Contrats!
the idling noise is normal as stated in the manual. :fadein:
happy_aggies
Re: S/C INSTALLED!
Postby Flipside909 » Tue Apr 29, 2003 12:53 pm
krooked Solara wrote: but i keep hearing like a 'sputtering' type of noise when it's idling.
That's normal.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Yanks0114 » Tue Apr 29, 2003 6:56 pm
The noise should be normal. For the first few hundred miles I even experience a noise at around 2000rpm but that has since ceased. Now the idleing noise stops at around 900rpm.
Postby krook » Tue Apr 29, 2003 9:02 pm
really? sputtering? heheh...kinda sounds like when you're sipping a drink and you reach the end of the drink, y'knowhadimean??? it's definitely gonna take some getting used to.
krook
Postby Yanks0114 » Wed Apr 30, 2003 1:01 pm
Thats exactly what it sounds like. I always though it sounded like fluid but you described it. It'll lessen over time as the SC breaks in and you'll get used to it
Postby Flipside909 » Wed Apr 30, 2003 1:43 pm
krooked Solara wrote:really? sputtering? heheh...kinda sounds like when you're sipping a drink and you reach the end of the drink, y'knowhadimean??? it's definitely gonna take some getting used to.
That's normal. As your S/C ages...you will start hearing more chatter from the moving parts inside the s/c.
www.clublexus.com
Flipside909
Postby Guest » Wed Apr 30, 2003 6:48 pm
How's the power? Are you running with 4psi or 5.5?
Guest
Postby krook » Thu May 01, 2003 12:16 am
4 psi with the stock pulley
krook
That gurgling noise...
Postby JoeB » Thu May 01, 2003 1:05 pm
krooked Solara, I know what you mean about the noise. I just got my S/C installed about 3 weeks ago. I had mine installed at Toyota from a guy that has done several of them. I'm not mechanically inclined enough to tackle a DIY on a project like that. Besides, I need the car to get me to work in the morning. When I first heard it, I had to ask too. I just didn't sound right. -Joe
JoeB
