SolaraGuy.com • View topic - Recieved and installed my bored out throttle body today
Postby supamouse09 » Fri Aug 24, 2007 4:06 pm
first of all thanks alot to Jim at proflow because he did a great job. i just took the car around the block and is everything is good. my idle is a little high at 950 but the ecu should adjust over time hopefully. will update you guys later.
01 Toyota Solara SLE V6 Manual Swap
supamouse09
Postby Americanctm10 » Fri Aug 24, 2007 5:54 pm
Congratulations! Did you notice a difference? do you have the spacer too?
Americanctm10
Postby supamouse09 » Fri Aug 24, 2007 9:29 pm
yes i have the spacer too, and when your a N/A is makes a world of difference. i also tried the ACIS power mod and it definately feels smoother.
oh i have a question for you guys though, what rpm does your car idle at??
supamouse09
Postby SleeperSolara » Fri Aug 24, 2007 9:54 pm
supamouse09 wrote:yes i have the spacer too, and when your a N/A is makes a world of difference. i also tried the ACIS power mod and it definately feels smoother.
Mine idles now around 500 RPM?? I think [just thinkin' on top of my head could be higher]
Yeah see i did teh ACIS mod but after awhile it felt weird when i went WOT, so i switched back.
Postby Midias » Sat Aug 25, 2007 5:34 pm
800ish
Postby TOYODRIVER01 » Sun Aug 26, 2007 3:02 am
800-900 rpm
TOYODRIVER01
Users browsing this forum: No registered users and 90 guests
