SolaraGuy.com • View topic - rub
rub
rub
Postby Stark33 » Tue Aug 28, 2007 8:26 pm
if i lower my 1999 solara sle v6 one 1.8 inches in back and 1.9 in front will it rub with my stock 16's?
Stark33
Postby woa_its_j3ff » Tue Aug 28, 2007 8:28 pm
jesus what kinda springs you using, intrax?
it might. we need more info. tire size , offset, etc.
Postby Stark33 » Tue Aug 28, 2007 8:31 pm
yeah intrax i want a big drop i dont exactly know all the info just stock wheels sixteens potenza g009 tires dont know numbers right now but what other springs should i look at with a pretty good drop?
Stark33
Postby woa_its_j3ff » Tue Aug 28, 2007 8:34 pm
i think thats too .. much. u might as well just get air bags. i mean its not a HUGE difference, but it's still noticable. I'd go with teins, or eibach. teins are just a lil bit more, and a lot more reliable.
Postby Stark33 » Tue Aug 28, 2007 8:36 pm
alright thanks man im looking at an tokico package online if you want to take a look.........http://www.racinglab.com/tok-hpp-hpk361.html
Stark33
Postby Stark33 » Tue Aug 28, 2007 8:40 pm
also when i but lowering springs and struts do i need anything else like a camber kit can you tell me more about that
Stark33
Postby ThatVietGuy » Tue Aug 28, 2007 8:42 pm
No you won't rub on STOCK wheels and tires :roll:
ThatVietGuy
Postby Stark33 » Tue Aug 28, 2007 8:43 pm
i wont rub with the intrax springs with 1.9 and 1.8 drop
Stark33
Postby woa_its_j3ff » Tue Aug 28, 2007 8:46 pm
dont get from racinglab, i've ordered from there. not a good site.
go on Performancecenter.com
and order the exact same set. springs/struts from there.
They are a lot more reliable. they may take a small while, but you'll get what you need. You won't need a camber kit since you aren't lowering your car that drastically imho, but it all depends. good luck.
Postby Stark33 » Tue Aug 28, 2007 8:48 pm
thanks alot man
Stark33
Postby indiglosolara » Wed Aug 29, 2007 10:17 am
1.8 and 1.9 is not that hugh off a drop....
You can go as low as 2.5 inches and still be ok esp with stock wheels...
I am dropped 3.2" in front and 3" on the rear of my car right now...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby ---CAMRAZY--- » Wed Aug 29, 2007 10:40 am
ThatVietGuy wrote:No you won't rub on STOCK wheels and tires :roll:
It will rub!!!!! HAr har!!
Postby **PoshPepper** » Wed Aug 29, 2007 11:53 am
Stark33 wrote:i wont rub with the intrax springs with 1.9 and 1.8 drop
NO!!!! I have a lower drop than that and I dont rub on my stock 17s. The offset on stock Toyota wheels is such that you dont have to worry about it.
The Original... SOcalLARA
Milt's OTHER ride
**PoshPepper**
