SolaraGuy.com • View topic - light bulbs watts
light bulbs watts
light bulbs watts
Postby Chhem87 » Tue Aug 28, 2007 10:22 pm
This question has probably already been asked, but the search engine is still screwed up. So has anyone ever heard replacing a light bulb over the recommended wattage will damage the headlamps housing or harness? Is that true? Can the Solara Head lamp handle a 100w bulb?
Chhem87
Postby woa_its_j3ff » Tue Aug 28, 2007 10:41 pm
why not just get HIDs?
Postby Chhem87 » Tue Aug 28, 2007 10:45 pm
Because my friend had a pair sitting around in his garage, and said he could not use them. I figured I will take them and try them out. I just not certain about the risks that I have been hearing about.
Chhem87
Postby NeFaRiOuS_SLE » Wed Aug 29, 2007 12:12 am
No... I've seen high-wattage halogens being sold that actually needs you to change the headlight wiring, not to mention that unless you do a lot of higher speed driving or live in Alaska, there's a good chance of the headlight housings melting too.
