SolaraGuy.com • View topic - Lowering Springs
Lowering Springs
Lowering Springs
Postby JRector » Thu Aug 30, 2007 9:31 pm
how long does it take to put them on urself? i hurd it takes like...16 hours, and does it take about amonth for them to actually break in and sit low?
JRector
Postby SolaraBlue » Thu Aug 30, 2007 9:46 pm
you HEARD wrong. whoever told you it took 16 hours is a retard...
Postby ThatVietGuy » Thu Aug 30, 2007 10:27 pm
It will take 16 hours if you have never handled a wrench, maybe...
ThatVietGuy
Postby xet » Fri Aug 31, 2007 12:01 am
or dont have a wrench.. and are bench pressing the car to get it off the ground
xet
Postby Astro » Fri Aug 31, 2007 9:48 am
I think the most time consuming thing is taking out the rear deck, side panels, and rear seats. If you're taking it somewhere, it's definately worth it to take those out ahead of time.
Postby Akfahad » Fri Aug 31, 2007 11:14 am
took me 2.5 hours to do a spring install on my maxima...but then again, I didn't have to remove the backseats/side panels either.
Postby Americanctm10 » Fri Aug 31, 2007 11:58 am
16 hours???? :o maybe he meant 1.6 hours...
you can rent a spring compressor at Autozone for cheap
Americanctm10
Postby indiglosolara » Fri Aug 31, 2007 12:08 pm
It takes abour 2 to 3 hours to do a complete install if you hve the right tools.
But for one's using basic hand tools it may take a little longer but shouldn't be more then 4 to 5 hours.
indiglosolara
Solara 2 xB
Solara 2 xB
