SolaraGuy.com • View topic - Help Please!!
Help Please!!
Help Please!!
Postby danwags999 » Wed Sep 12, 2007 10:35 am
I have a 99 Camry 1MZ-FE. I just bought the cp-e intake and I'm in the process of installing it. Some of the wiring doesn't match up. In the instructions, the picture shows the ecu labeled as HZ. My ecu on my Camry is labeled HX. Is this a problem? If not my question is are the wires just located in different connectors? Or are the wires located in the same place but different colors? Thanks for any help~!
danwags999
Postby Americanctm10 » Wed Sep 12, 2007 10:38 am
the wires should be in the same place. And the colors should match just like in the pics in the instructions. Take some pics and post them up so i can see where you are.
Americanctm10
Postby danwags999 » Wed Sep 12, 2007 11:07 am
The first picture is the picture of the instructions. Notice how the ecu is labeled HZ and mine is labeled HX.
Now the instructions say to locate the solid red wire on the connector E7. Well I don't have any solid red wire on connector E7:
However there is a solid red wire on connector E10:
danwags999
Re: Help Please!!
Postby unbalancedwood » Wed Sep 12, 2007 11:08 am
danwags999 wrote:I have a 99 Camry 1MZ-FE. I just bought the cp-e intake and I'm in the process of installing it. Some of the wiring doesn't match up. In the instructions, the picture shows the ecu labeled as HZ. My ecu on my Camry is labeled HX. Is this a problem? If not my question is are the wires just located in different connectors? Or are the wires located in the same place but different colors? Thanks for any help~!
Well it is made for the solara...javajoe is i guess having the same problem on his camry. Call the guys over at CPe...too bad you didnt wait around for our GB...
unbalancedwood
Postby Americanctm10 » Wed Sep 12, 2007 11:32 am
If i remember correctly mine was HX too. But my wires matched up. Do not use the red-wire from E10, you need to hook it up to E7. It should give you a number to follow as well. Like wire # 17, and the connector should have numbers on it, like 10, 15, 20. Just count down or up from those numbers and see what color the wire is.
Americanctm10
Postby Sebas007 » Wed Sep 12, 2007 11:34 am
Different ECU...different connectors. I don't know pretty much about the difference between those 2 ECU type...but you'll have for sure to find and identify every equivalent wires. No an easy job. Perhaps, you may ask Java about his own experience...
Postby Dawgz » Wed Sep 12, 2007 11:35 am
it looks like u have a red wire with silver dashes on that connector, but not the same pin....
Postby danwags999 » Wed Sep 12, 2007 2:07 pm
So if I find the same pin # it will be the same wire? Correct?
danwags999
Postby Americanctm10 » Wed Sep 12, 2007 2:19 pm
That's my guess. Use the numbers on the connectors and match them with the numbers in the instructions. But, call the number on the instructions and talk to someone over at CP-E to see if they know the exact wires.
Americanctm10
Postby JavaJoe_2 » Wed Sep 12, 2007 7:13 pm
Americanctm10 wrote:That's my guess. Use the numbers on the connectors and match them with the numbers in the instructions. But, call the number on the instructions and talk to someone over at CP-E to see if they know the exact wires.
JavaJoe_2 wrote:I love the CP-e. BUT as for product support Josh told me "I don't know if it would work" (we all know it does) and as for wiring he said "good luck"
Got Boost?? :sweet:
JavaJoe_2
Postby JavaJoe_2 » Thu Sep 13, 2007 4:51 am
When I get home tonight I will check thru my notes. We should compare and go from there.
Got Boost?? :sweet:
JavaJoe_2
Postby SleeperSolara » Thu Sep 13, 2007 7:03 am
Well from lookin' at your pictures.
See how they tapped the red solid wire wit the silver stripe.
Look at it's location....
Look under the yellow wire, there is a solid red wire wit a silver stripe just like the one in the picture, that could be the wire you're suppose to tap in i think.
Just takin' a guess.
Postby Sebas007 » Thu Sep 13, 2007 7:35 am
I see 2 way to see it...
color to color match...
red w/silver on both ECU model are the same
OR
pin# to pin# match...
red w/silver in pin #1 = yellow w/ silver in pin #1
Postby JavaJoe_2 » Tue Sep 18, 2007 5:04 pm
Any luck yet?? :lol:
Got Boost?? :sweet:
JavaJoe_2
Postby unbalancedwood » Wed Nov 07, 2007 2:36 pm
BUMP, ran into the same probelem today....so whats the correct wire for us with the HX ECU?
unbalancedwood
