SolaraGuy.com • View topic - White Interior
White Interior
White Interior
Postby JRector » Fri Sep 28, 2007 9:59 am
is it possible to take off the wood grain trim and sand it all down and paint it white and to take the whole middle console out and sand it and have it painted white and take off the plastic pieces that are on the door panels and have them sanded and painted?? i cant get the damn door panels off
JRector
Postby rollaevo99 » Fri Sep 28, 2007 10:16 am
yes you can...... but I would suggest to let the professional do it for you, or you can do it yourself but you got to have patience :wink:
Postby woa_its_j3ff » Fri Sep 28, 2007 10:43 am
have a professional do it. what rollaevo said. if you mess up, .. oh man..
Postby philosophicaljt » Fri Sep 28, 2007 10:51 am
why do you want white instead? If its not done perfectly, I would think it would cheapen the feel of the interior. If you have made up your mind on this and cannot be talked out of it, I would at least make sure you had a professional do it.
Have a photoshop of what you have in mind?
2004 Solara SLE V6
Search
philosophicaljt
Postby Toy1mzfe » Fri Sep 28, 2007 11:23 am
umm to me, white is a bit umm. sorry tacky but thats my taste. i like the wood luxury.
but if u wanna do it yea its possible. im not sure how u take it off but if u are able to rattle can woudl work.
sand it down a bit.
Clean it up.
put some priemer several coats. (around 7 mins between coats)
then color coats (15-20mins between coats)
then clear coat (10-15mins between coats)
FYI- in between coats as u spray each can, start out light then heavier coats.
Postby Solarafreek » Fri Sep 28, 2007 11:40 am
Get some vinyl from Kenny(indigo)...dont paint.
Solarafreek
Postby LatinUSMC » Fri Sep 28, 2007 1:14 pm
Yeah ^^^^^Vinyl and heat gun will be ezier to fix /discard if you mess up..i tried it..and sanded/painted does look tacky.. vinyl is a much easier /safer option..you will get tired of it after a while..i had carbon fiber trim for 3 months..be care ful when you pop out the wood trim..tabs break eazily. :P
LatinUSMC
Postby indiglosolara » Fri Sep 28, 2007 1:41 pm
If you need some vinyl let me know...
indiglosolara
Solara 2 xB
Solara 2 xB
