SolaraGuy.com • View topic - Hid Connection
Hid Connection
Hid Connection
Postby facevedo17 » Mon Oct 01, 2007 5:53 pm
hello Im not looking for DIy I've already done it but just curious how most of you guys that upgraded to HID's installed them
My Installer had an Relay install and its getting power directly from the Battery , attached a fuse and everything has anyone done different ?Ill post pics soon
facevedo17
Postby woa_its_j3ff » Mon Oct 01, 2007 8:56 pm
why would it be linked to battery? mine is with the headlight itself, draws power from the wiring harness and wutnot.. fuse?? whoa.. :o .. ill be waiting on the pics.. never heard of this kinda setup before..
Postby Dawgz » Mon Oct 01, 2007 9:18 pm
U want to see my setup?
Postby hskrsolara » Mon Oct 01, 2007 9:38 pm
sounds like the same way I connected mine...i believe the only reason the oem plugs are incorporated is for on/off switching. i'll have to go look and make sure...
hskrsolara
Postby Gangis » Mon Oct 01, 2007 9:39 pm
My HID system (courtesy of RDKamikaze) only uses the original wiring as a signal with the relay harness to switch the lights on/off, otherwise it draws from the battery. Took me a while to figure it out as the instructions were in chinglish. :P
Gangis
Re: Hid Connection
Postby bronzemaxell » Tue Oct 02, 2007 5:43 am
facevedo17 wrote:hello Im not looking for DIy I've already done it but just curious how most of you guys that upgraded to HID's installed them
i have my solara setup with power directly from battery, fuses, and along with relay to headlight plugs, and never has problems
i have another vehicle that doesn't have relay or fuse, and get power directly from light bulb socket, it seem to blow a headlight fuse every one in while, and seem more problematic than the one that has inline fuses and relay setup.
bronzemaxell
Re: Hid Connection
Postby facevedo17 » Tue Oct 02, 2007 8:57 pm
are your Drl disable aswell????
facevedo17
Re: Hid Connection
Postby bronzemaxell » Wed Oct 03, 2007 6:12 am
the solara is with inline fuse and relay, i did pull the plug on the passengerside infront of the windshield to disable the DRL, works fine.
but for the vehicle that keep blowing fuse once a year, it doesn't even have DRL, it is a 1993 camry, i am just too lazy to custom make a wire harness for it. the original headlight wiring on the vehicle is rated for 55watt bulbs, but HID draw much more current (more than 55watt) during initial startup to fire the bulb, after the HID bulb reaches the full brightness, then it settle at 35 watt. i am just stating that i've experience problem with connecting the ballast to the headlight plug, my fuse does a very good job protecting my overloaded headlight circuit, and like i said earlier, changing a blown headlight fuse once a year is not too bad for me.
bronzemaxell
Postby bunthy » Wed Oct 03, 2007 7:59 am
^ correction, it draws alot more volts at inital start up, close to 17 volts, i.e. oem plugs run at 12v.
heres how I have mine and how I did it for sahuddleston:
-OEM plug (both + and -) to relay terminal 85 and 86 respectivly, with a 1N4005 inline with the postive wire.
-Relay terminal 30 goes to inline fuse 30amps to + of battery terminal.
-Relay terminal 87 spliced to go to each seperate ballast with an inline fuse 15amps from the relay to the ballst.
-With each ballast, I grounded them to the car frame.
Had done this to 5 cars and no problems since.
bunthy
Postby philosophicaljt » Wed Oct 03, 2007 8:54 am
You REALLY need a seperate relay and fuse. I mena, I know you think its not much, but it is.
2004 Solara SLE V6
Search
philosophicaljt
Postby facevedo17 » Wed Oct 03, 2007 3:16 pm
as hard as it may seem it does help and plenty
facevedo17
Postby fastsolara » Wed Oct 03, 2007 6:56 pm
i have 2 sets, one for my main lights and the other for my fogs..
neither set are wired to the battery except the ground on my main lights.. i have no relays or other power supplys.. these were plug and plays and snap right into the factory harness... have no problems with them and they are just as bright as any other system.
there is more than plenty of sufficient power from the wiring harness..
remember, takes even less power to run the ballast than the factory halogens
2000 Solara SE V6 5sp w/ all options, 57k
6000k HID head lights
8000k HID fog lights
Reverse Indiglo Gauges
Performance Chip
Custom black grill (very nice)
20% tinted windows
Supra Brake Calipers
fastsolara
Postby fastsolara » Wed Oct 03, 2007 6:57 pm
oh, the 2 kits i have are from different companies, the ones for my fogs did have a seperate fuse for each but still no relay..
Performance Chip
20% tinted windows
fastsolara
