SolaraGuy.com • View topic - gen1-1.5 hid ballast mount?
Postby SolaraBlue » Tue Oct 02, 2007 4:35 pm
i did a quick search and could only find info on the gen2... im trying to mount the drivers side hid ballast and cant find a place to do so.... anyone have some info or pointers? thanks
Postby Dawgz » Tue Oct 02, 2007 4:40 pm
neat the bottom right side of the battery. or the rail near the battery (over the headlight, on the side)
Mine had a double sided tape on the back of the ballast, so i stuck it to the battery and used zip tie over the "screw hole" to secure it just-incase the tape were to come off...
Postby bronzemaxell » Tue Oct 02, 2007 6:52 pm
i put the slim D4S denso between the battery and the fuse box, it is well hidden, hardly able to see it.
bronzemaxell
Postby RichD978 » Tue Oct 02, 2007 7:25 pm
you guys all have messy wiring jobs.. shame on all of you
RichD978
Postby SleeperSolara » Tue Oct 02, 2007 7:58 pm
I was goin' to mount my D2S slim Denso ballast under my headlights wit a cover.
Postby Dawgz » Tue Oct 02, 2007 9:04 pm
RichD978 wrote:you guys all have messy wiring jobs.. shame on all of you
Lets se urs
Postby Akfahad » Wed Oct 03, 2007 5:51 am
Hahaha....
SolaraBlue....no pic for you, but if you stand in front of the car on the drivers side, facing the battery...there should be a hole in the frame next to the radiator fan. the frame is vertical going down to the ground, just find the right screw and your good. That's where I put mine, I just happened to have the right screw for the hole.
Postby fastsolara » Wed Oct 03, 2007 7:12 pm
my ballast on drivers side is located under my battery tray to the right side (lookin down at it).. it fits perfectly there and doesnt get hurt at all or pinched.. all the wires hide much better that way
2000 Solara SE V6 5sp w/ all options, 57k
6000k HID head lights
8000k HID fog lights
Reverse Indiglo Gauges
Performance Chip
Custom black grill (very nice)
20% tinted windows
Supra Brake Calipers
fastsolara
