SolaraGuy.com • View topic - Ballast or the HID light bulb question
Postby socalisolara » Sat Oct 13, 2007 11:47 pm
Just installed HID on my 00 Solara and I am having a problem with one of the HID light bulbs turning off on its own. I checked all the connections, ballast, fuse, and etc and i am still having a problem where the passenger side HID is going on and off on its own. Can anyone help?
socalisolara
Postby woa_its_j3ff » Sun Oct 14, 2007 10:31 am
the ballast.
had the same issues.
swap the ballasts with eachother, then you'll know if its the ballast or the bulb.
chances are it's the ballast and not the bulb itself.
good luck.
Postby fastsolara » Sun Oct 14, 2007 9:52 pm
its probly the connection... you more than likely have a lose wire in the connector..
2000 Solara SE V6 5sp w/ all options, 57k
6000k HID head lights
8000k HID fog lights
Reverse Indiglo Gauges
Performance Chip
Custom black grill (very nice)
20% tinted windows
Supra Brake Calipers
fastsolara
Postby raneshraj209 » Thu Oct 18, 2007 3:11 am
the same thing was happening to me and it was the connection so make sure everything is connected
raneshraj209
