SolaraGuy.com • View topic - will these wheels fit?
Postby woa_its_j3ff » Sun Oct 14, 2007 10:41 am
18x7.5 inch rims,
coming off an IS300?
rear tires would be 235/40/18
front tires would be 225/40/18
thanks.
Postby woa_its_j3ff » Sun Oct 14, 2007 2:48 pm
wow. no one knows.
Postby ThatVietGuy » Sun Oct 14, 2007 2:50 pm
Offset...?
ThatVietGuy
Postby Jon11582 » Sun Oct 14, 2007 3:44 pm
If i remember right, you need spacers because the offset is too much.
2000 Black Solara SE
Jon11582
Postby woa_its_j3ff » Sun Oct 14, 2007 3:56 pm
offset I'm guessing is + 40?
they are coming off an IS300..
example pics of what they look like.. (actual rims are gunmetal with polished lip)
Postby woa_its_j3ff » Sun Oct 14, 2007 7:29 pm
bump bump
Postby ---CAMRAZY--- » Sun Oct 14, 2007 8:06 pm
Get correct offsets for anyone to answer you.
Postby woa_its_j3ff » Sun Oct 14, 2007 8:40 pm
ok correction.
it is a +42 offset.
Postby iinokturnolii » Sun Oct 14, 2007 9:37 pm
woa_its_j3ff wrote:you guys are too ignorant. im done with this forum.
welcome back! Image
iinokturnolii
Exotic Herb Sampler
Exotic Herb Sampler
Postby Toy1mzfe » Sun Oct 14, 2007 10:23 pm
They should fit.
Seems like the rear has a bit more rubber than what is commonly use.
Postby woa_its_j3ff » Sun Oct 14, 2007 10:26 pm
i have this feeling the rears will rub... :-s
Postby ThatVietGuy » Sun Oct 14, 2007 10:33 pm
Use the rears in the front and it'll be fine
ThatVietGuy
Postby woa_its_j3ff » Sun Oct 14, 2007 10:35 pm
thanks guys. any additional info will help.
Postby woa_its_j3ff » Mon Oct 15, 2007 7:28 am
I double checked with seller. it is +37 offset.
will this still fit, or no?
sorry for the hassle.
thanks.
Postby woa_its_j3ff » Mon Oct 15, 2007 9:14 am
bump
