SolaraGuy.com • View topic - Drum to disk conversion?
Postby DjNoRhythm » Mon Oct 15, 2007 8:46 pm
Greetings,
What is involved in converting my rear drum brakes to Disk?
I think I just need the Master cylinder, proportioning valve and the rear brake parts. Is this the case?
DjNoRhythm
Re: Drum to disk conversion?
Postby Gregtrd » Mon Oct 15, 2007 10:22 pm
DjNoRhythm wrote:Greetings,
dont need master cylinder, all you need is the rear assembly brake parts. i think the easiest way is to go to a dismantlers yard and buy the rear brake assembly and do a stright swap out. cake job, as long as you have the tools and some skill you can handle it. do you have abs? some 4cyl. camry solara came with abs with rear drum brakes, i think the rear disc. brake only helps if you have abs.
Gregtrd
