SolaraGuy.com • View topic - Injen Intake sucking in water
Postby SC V6 » Tue May 06, 2003 7:43 pm
I was driving home from my g\fs house and I noticed this weird noise again. It was raining, and I know that its my injen intake sucking in water. It makes the whole car vibrate when the water is on the filter. I need to get that valve that u put into the intake, to get rid of water. I don't know where to get this.. can someone help... also, I didn't think water could get up to the intake... but it is. I put my stock airbox back on, and the problem stopped completly. thanks in advance
Scott
SC V6
Postby NASTY » Tue May 06, 2003 7:45 pm
...i thought that was only a problem with CAI's?
'01 SLE V6
NASTY
Postby SC V6 » Tue May 06, 2003 7:57 pm
pretty much it is...
SC V6
Postby Mole » Tue May 06, 2003 7:58 pm
does rain flood to your knees or something? short ram intakes (which i assume you have) is almost impossible to get water sucked in.
anyway what the item is called is "bypass valve." i believe aem has that.
Postby SC V6 » Tue May 06, 2003 7:58 pm
Alright... so after doing some research... I need to get an air bypass valve. Now the problem is, that Injen doesn't offer this, BUT aem does. Would I just get the right size diameter, and put it in?... would that work?
thanks
no I don't have water at my knees... somehow water splashes up and gets it a little wet... it doesn't suck it in, it just covers the intake filter, and it sounds horrid... its not a whole lot of water
SC V6
Postby Flipside909 » Tue May 06, 2003 11:49 pm
Scottv6 wrote:Alright... so after doing some research... I need to get an air bypass valve. Now the problem is, that Injen doesn't offer this, BUT aem does. Would I just get the right size diameter, and put it in?... would that work?
thanks
The AEM bypass is only for real CAI units..not short ram intakes. Do more reasearch since you're not even close to solving your problem FYI.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby CrazyCraig » Wed May 07, 2003 8:32 am
A bypass valve is used in the event that your intake gets submerged in water. Your either gonna' hafta' build your self an air box to keep the majority of water at bay, or go back to the stock intake with a K&N.
CrazyCraig
CrazyCraig
Postby SC V6 » Thu May 08, 2003 4:11 pm
I solved the problem... The piece of tube that connected from the Resonating tank, to the actual air box, was getting water in it.. and sloshed back and got onto the filter.. so I put tape on the end, and its fixed.. anyway.. I wanted to take that piece completly out, but I tried, and i couldn't find a way to get it out.. it would envolve taking the fuse box off.. and the bolts are too hard to get to.. anyway.. its fixed.. if anyone knows how to take this piece completly out.. please send me a message.. thanks
Scott
SC V6
