SolaraGuy.com • View topic - TRD Muffler Help...
TRD Muffler Help...
TRD Muffler Help...
Postby SirMacDaddy » Sun Oct 28, 2007 9:03 am
So i just got a TRD muffler and i just cant get those bolts off of the original muffler. is there anything i am doing wrong? its just taking those bolts off right?
Can someone please help me out with tips?
Thanks for your input
Omar
SirMacDaddy
Postby AllShowNoGo » Sun Oct 28, 2007 9:08 am
it sounds like your gonna need some acetylene and oxygen to get those rusty bolts out.
AllShowNoGo
Postby SirMacDaddy » Sun Oct 28, 2007 9:09 am
how would i go about doing that?
SirMacDaddy
Postby Ruski » Sun Oct 28, 2007 9:21 am
try some PB Blaster ,let it soak into the bolts and then hit it with an impact gun or a breaker bar .. or take it to a shop..
Postby PhreakdOut » Sun Oct 28, 2007 9:52 am
Aren't the studs welded to the Gen 1 muffler flange? You just remove the nuts.
Postby PhreakdOut » Sun Oct 28, 2007 10:00 am
This is a picture of the Gen2 Solara / Camry V6 muffler. The inlet flange design should be the same. Studs are welded to the flange and your would remove the nuts to get the muffler off.
This is done because it is easier on the assembly line to keep the parts together until the assembler can tighten up the flange.
Postby AllShowNoGo » Sun Oct 28, 2007 10:00 am
take it to a shop with a torch to burn out those bolts.
AllShowNoGo
Postby JavaJoe_2 » Sun Oct 28, 2007 10:43 am
Ruskimafia wrote:try some PB Blaster ,let it soak into the bolts and then hit it with an impact gun or a breaker bar .. or take it to a shop..
x2
Got Boost?? :sweet:
JavaJoe_2
Postby SirMacDaddy » Sun Oct 28, 2007 11:10 am
still havent had any luck with it...i think i am just going to have to take it into a shop tomorrow
SirMacDaddy
Postby Midias » Sun Oct 28, 2007 12:01 pm
On my TRD muffler I had to cut the bolts ant put in fresh ones. I used an angle grinder and cut off wheel
Postby JavaJoe_2 » Sun Oct 28, 2007 12:12 pm
Have you tried the PB Blaster?
If you don't have an impact, just use a ratchet and a long pipe. Or breaker bar. When they start to loosen, go two turns and back off, respray and turn some more, loosen, then go the rest of the way.
Use only a 6 pt. socket, a 12 pt. will probably round the nut.
Got Boost?? :sweet:
JavaJoe_2
Postby SirMacDaddy » Sun Oct 28, 2007 4:50 pm
does anyone have a ballpark of how much this should cost to do?
SirMacDaddy
Postby Midias » Sun Oct 28, 2007 5:06 pm
SirMacDaddy wrote:does anyone have a ballpark of how much this should cost to do?
At any reasonable shop 50 bucks
Postby Ruski » Sun Oct 28, 2007 5:07 pm
try Pb blast first like javajoe and i Stated
Postby PhreakdOut » Sun Oct 28, 2007 5:09 pm
^^ This really is not that hard. Just take a breath and read the postings carefully.
> The nuts should be removed, not the studs. The studs are welded to the OE muffler.
> If it have not been replaced before, the OE is low 409 grade stainless steel. 409 will get rust on it and make it difficult to remove but not impossible.
1) Use a wire brush or something similar to clean off surface rust from the threads of the stud and around the inside edge of the nut.
2) Use some type of penetration lube spray. PB Blaster is good. Just use anything available.
3) Use a 6 point deep socket to remove the nuts. A breaker bar is best or use a socket wrench and add a pipe or some kind of extension to the handle to give you more leverage.
4) Turn carefully! Nice and slow. If it will not budge with mild force, then apply heat.
5) Propane torches are cheap. Any hardware store will carry a kit for about $25-$35 dollars. Heat the nut evenly all the way around. Work with one nut at a time. Do not try to heat the stud too. You want the metal of the nut to expand so it is easier to remove.
6) While the nut is hot, quickly use the wrench to remove.
7) If it still will not budge, then look into a nut splitter. AutoZone may have one for rent. Check with them. It looks like this:
Basicly a tool steel point is driven into the side of the nut until it splits open. Hopefully you have clearance to fit this onto the flange.
8 ) Worst case scenario: If the mid pipe looks bad too, replace it. Cut the OE system in two with a wheel blade pipe cutter. You can use an aftermarket mid pipe, have a shop make one for you or get the OE midpipe.
Please post up pictures if you still have problems.
