SolaraGuy.com • View topic - S/C Good Idea? Bad Idea?
Postby Dannymihaylov » Wed Nov 07, 2007 6:46 am
Hello Solara guys,
I have a 00' solara, at 160K, good idea or bad idea to put in the TRD Supercharger? Please give me detailed answers, not just yes and no.
Dannymihaylov
Postby Midias » Wed Nov 07, 2007 7:01 am
yea and search
Postby facevedo17 » Wed Nov 07, 2007 7:23 am
go for it if she is running strong ...get a compression test aswell ......
facevedo17
Postby DatSRBoi » Wed Nov 07, 2007 7:30 am
No....Also if your asking for details you are definitely should not get one.
Postby Dawgz » Wed Nov 07, 2007 7:54 am
the question isnt if its good or bad, its how the hell do u think ur gonna get one!
Postby Dannymihaylov » Wed Nov 07, 2007 7:56 am
I have a friend that can still get one :) T.dot.... lot'sa connections :D
Dannymihaylov
Postby CamryOnBronze » Wed Nov 07, 2007 8:03 am
1. I wouldnt say there are all of the answers to this question on the forum already.
2. Asking questions is better than doing it with no idea what youre doing.
3. They arent that difficult to find if you have the money.
I would say you need to take a serious look at the condition of your engine and transmission. Do a compression and leakdown test. Also consider upgrading your brakes, suspension, and exhaust as a part of the supercharger install and make a decision from there. The timing belt is also something to consider. Have your engine checked out in detail with a skilled mechanic and work from there.
I believe King (Eye8piussies) is boosted with high mileage on his gen 3 camry and is still running strong- its all about maintenance and the condition your motor is currently in.
Good luck!
Postby Dannymihaylov » Wed Nov 07, 2007 8:33 am
I just had the tranny fluid changed... the guy was suprised how clean it was before he changed it... I usually change my oil at 4,000 KM, just because I push the car very often. I flush out the engine pretty often.
So one other question, anyone know any good guys that can check my engine for the S/C? and also approx price range on these tests?
Dannymihaylov
Postby CamryOnBronze » Wed Nov 07, 2007 8:39 am
you can do a compression test yourself with a kit for about 25 bucks- that will tell you a lot of what you need to know. How long have you owned the car? Just take into consideration your maintenance records and when things have been changed- have the necessary maintenance tasks been kept up to date with mileage?
Postby icelove82 » Wed Nov 07, 2007 9:11 am
How much are you paying for S/C if you are getting one?
I am just wondering
icelove82
Postby SleeperSolara » Wed Nov 07, 2007 9:19 am
icelove82 wrote:How much are you paying for S/C if you are getting one?
I am just wondering
+1 for me too.
Shoot my friend can get one when i asked him a couple months ago.....
Not sure now if my friend can get one.
Postby 99V6solaraSE » Wed Nov 07, 2007 9:24 am
shoot ask your friends if they can find me one...:lol:
99V6solaraSE
Postby Sebas007 » Wed Nov 07, 2007 9:34 am
I would almost kill to have my Gen 2 boosted...I would say go for it but like some guys here said do the basics before :
- Cylinder compression test (do it when the engine is cold be cause the tool is in steel and your engine block in aluminum...it can strip your spark plug inlet if the engine is hot)
- Check your or change your timing belt
- Check for any leak before boosting it even low boost
Beside basic check up I don't see anything wrong. Also, you'll always find someone to buy a TRD SC on here, toyotanation or ebay. So the risk is decreased if you don't want it anymore !
I test drove my friend GTI (told me I was the only who test drive his car the way should be tested...) and I loved the boost of the turbo. This turbo setup react just like a SC. Very quick boost (1800 RPM) almost top power at 2400 RPM to the end ! The best for you would be to test drove a car with a low boost turbo or SC.
I say YES !
Postby d4008 » Thu Nov 08, 2007 8:09 am
i say go for it, but its gonna be one pretty pennie for a s/c
its almost done, cant wait til spring.
d4008
Postby d4008 » Thu Nov 08, 2007 8:11 am
hey is there any truth to the rumor that gen1 can use a scion TC turbo in it insteard of the s/c
d4008
