SolaraGuy.com • View topic - How to quiet the exhaust
Postby Ragtop George » Sat May 10, 2003 9:29 pm
My new Y pipe is very noisy, it rings under heavy throttle. It may not be the sort of thing that is noticable in a coupe, but with the top down it is quite annoying. If you tap the stock exhaust piping with a wrench, it goes clunk. If you tap the stainless piping on my Y pipe, it rings like a bell. Is there any way of damping this out? Would header wrap work? Or do I have to replace the piping?
Thanks
George
2002 Solara Convertible Automatic
TRD Supercharger, 6 PSI pulley
Apexi WS exhaust, custom Y pipe
TRD RSB on "track" setting
Ragtop George
Postby Turbosolara » Sat May 10, 2003 11:44 pm
The only thing you can do is take it to local muffler shop and ask them. most likely i think the y pipe is a bit too long, so it doesnt fit perfectly. or maybe the gasket is bad or missing? or loosen bolts?
Re: How to quiet the exhaust
Postby Flipside909 » Tue May 13, 2003 11:26 am
Ragtop George wrote:My new Y pipe is very noisy, it rings under heavy throttle. It may not be the sort of thing that is noticable in a coupe, but with the top down it is quite annoying. If you tap the stock exhaust piping with a wrench, it goes clunk. If you tap the stainless piping on my Y pipe, it rings like a bell. Is there any way of damping this out? Would header wrap work? Or do I have to replace the piping?
Thanks
George
Adding resonators will help as well as wrapping it with header wrap. What kind of piping did your shop use? All in all, the noise level of your exhaust with your new Ypipe will never be as muted as the stock one.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
