SolaraGuy.com • View topic - SAFC 2 Install Help
SAFC 2 Install Help
SAFC 2 Install Help
Postby 20SoLaRa02 » Sun Nov 25, 2007 11:17 pm
Hey everyone,
I have a couple questions hopefully someone can help me with. First I found this wiring diagram from a thread about installing the SAFC2:
http://www.solaraguy.org/viewtopic.php? ... ll&start=0
the diagram says its for a gen 1. I was wondering if this would also apply for a gen 1.5, since they run the same engine. Also, this looks identical to the T10-f diagram on the safc 2 wiring manual except the diagram above has more things listed, which i don't believe i need to tap into all of those. Can someone confirm this is the correct diagram to use.
Last question, what type of airflow/pressure sensor is our vehicle? hot wire/flap/pressure sensor or Karman type frequency sensor?
Thank you in advance
-Michael
20SoLaRa02
Postby Dawgz » Mon Nov 26, 2007 9:19 am
Yes, that diagram is correct in SOME wires, but some of those wires are NOT correct.
Sensor Type = Hot Wire
Sensor # = 12 in & 12 out
Sensor Cal = 1 in & 1 out
Car Select = 6 Cyl (up arrow)
I recently installed one on another solara...and a few wires were not the same... if u can wait a week, i can fix that diagram for u.
Postby 20SoLaRa02 » Wed Nov 28, 2007 11:15 am
Hey Dawgs,
i would appreciate it if you could fix that diagram whenever you get a chance, but the sooner the better :).
Thanks,
Michael
20SoLaRa02
Postby 94CoupeV6 » Wed Nov 28, 2007 5:35 pm
Why should he do your dirty work?
94CoupeV6
Postby DaTwUnKrAziEpInOy » Wed Nov 28, 2007 9:30 pm
actually...I'm in need of help wiring up the SAFC too... please do share what wires need to be tapped/spliced into. Thanks
DaTwUnKrAziEpInOy
Postby Dawgz » Wed Nov 28, 2007 9:37 pm
ill have the revised one by this weekend, hopefully.
Postby CamryOnBronze » Wed Nov 28, 2007 9:37 pm
94CoupeV6 wrote:Why should he do your dirty work?
probably because he has wired two of them before and offered to- why not? :lol:
Postby 20SoLaRa02 » Wed Nov 28, 2007 10:27 pm
thanks again for your help. whenever you have time that would be great
as for 94CoupeV6 dawgs offered to do it, if i could wait a week. so before you post, you should learn how to read all the posts.
thanks
20SoLaRa02
Postby 20SoLaRa02 » Tue Jan 29, 2008 4:19 pm
ok, i finally got it installed and it seems to work. i haven't driven the car yet. the one thing i haven't done yet is install the knock sensor. the diagram i'm using is similar to the one at the top of this thread but it shows two knock sensor wires. According to the other diagrami used Knock sensor 1 is the same as the "PE" in the diagram on the first post and the knock sensor 2 is the wire right next to it.
My first question is does our car have two knock sensors? If not i'm assuming i'll connect it to the "PE"/knock sensor 1. If we do have 2 knock sensors which one do i connect and how do i know?
thanks
Michael
20SoLaRa02
Postby Dawgz » Tue Jan 29, 2008 4:27 pm
Yes, we have two knock sensors.
And as to which one to connect to, the one behind the sc blows for people...usually. so thats the bank 1 knock sensor.
Since that one can give u false readings, id suggest u monitor the front knk since it doesnt REALLY have the sc rite ontop of it...
My knk bank 2 blew because of a bad initial dyno run (ran it too rich). So rite now im running both readings off of the bank 1 knk.
