SolaraGuy.com • View topic - where to put?
where to put?
where to put?
Postby woa_its_j3ff » Fri Nov 30, 2007 7:40 am
Im going to put 3000K hid for my fogs soon and was wondering where the heck to mount the ballasts... and woul di Need to take off my front bumper to do this? :-s, it seems to be a lot more complicated than doing the headlights.
thanks in advance.
Postby akora12 » Fri Nov 30, 2007 8:59 am
A member on here ('00vegas-solara) mounted his ballasts under the headlights. I think it makes for a clean install, plus it's out of sight. Regardless, I wouldn't think removing the bumper would be necessary. Here's the link.
http://www.solaraguy.org/viewtopic.php?t=30298
Postby woa_its_j3ff » Fri Nov 30, 2007 10:31 am
^thanks very much
Postby SleeperSolara » Fri Nov 30, 2007 12:41 pm
akora12 wrote:A member on here ('00vegas-solara) mounted his ballasts under the headlights. I think it makes for a clean install, plus it's out of sight. Regardless, I wouldn't think removing the bumper would be necessary. Here's the link.
Yeah i was thinkin' of mountin' my HID ballasts under my headlights. lol.
Postby hskrsolara » Sat Dec 01, 2007 9:50 am
under the battery and behind the washer fluid refill neck.
hskrsolara
Postby hskrsolara » Sat Dec 01, 2007 9:51 am
I have an optima battery, no worry about acid. ;)
hskrsolara
Postby sahuddleston » Sat Dec 01, 2007 12:34 pm
i mounted mine adjacent to the bumper support. i did remove the headlights to do so, i never had any issues with water seeping in.
2012 Ford Shelby GT500
2013 Hyundai Genesis 4.6
sahuddleston
Postby Solorange » Mon Dec 03, 2007 6:37 pm
I mounted my ballast for my headlights for the drivers side on the mount for the air bag sensor. I pulled the headlight out and used a zip tie to hang the ballast from that bracket. There was a hole on the bracket for the air bag sensor and on the ballast. Then I used some 3m double sided tape and stuck that on the side out air bag sensor mount and stuck that bad boy on there. Its not going anywhere. That may be an option if you haven't already mounted your other ballast there.
Postby Yanks0114 » Mon Dec 03, 2007 9:09 pm
Here are pics of my HID install: http://travel.webshots.com/album/188391551CUIZyt
Postby woa_its_j3ff » Mon Dec 03, 2007 9:34 pm
thanks Yanks! ill keep this in my favorites for future reference. just gotta find room since a lotta electronics running around and since my hids ballasts for my headlihts are already mounted by windshield washer area and by fuse panel area in the back of it
