SolaraGuy.com • View topic - question regarding superpro bushings
Postby rob96826 » Wed Dec 05, 2007 1:02 am
do you need to reuse the metel sleeve on the stock bushings when replace the dog bone mount & frnt lower control arm bushings with superpro. also with the dogbone mount, the swirl with the bigger bushings has to face a certain way?????
rob96826
Re: question regarding superpro bushings
Postby SleeperSolara » Wed Dec 05, 2007 7:32 am
rob96826 wrote:do you need to reuse the metel sleeve on the stock bushings when replace the dog bone mount & frnt lower control arm bushings with superpro. also with the dogbone mount, the swirl with the bigger bushings has to face a certain way?????
The metal sleeve you cut out for the dogbone bushin'.
For the front control arm i think you need to cut out the metal sleeve too.
How did you manage to take off the front control arm??
I've been havin' a hard time tryin' to take off the front control arm.... :(
Postby sydemoid » Wed Dec 05, 2007 9:57 am
i wanna redo all my bushings soon, does super pro offer more than control arm, and dogbone bushings?
Already got the dogbone with torquerod, would like to do all engne mounts if possible.
sydemoid
Postby SleeperSolara » Wed Dec 05, 2007 11:46 am
sydemoid wrote:i wanna redo all my bushings soon, does super pro offer more than control arm, and dogbone bushings?
That i know of they do offer the front control arm bushin's, Rear control Arm bushin's, and they did offer the Right Rear Engine bushin', but that i know of Greg is the only one that has the Right Rear Engine bushin' cause of lost interest in the Right Rear Engine bushin'....
