SolaraGuy.com • View topic - for people with superchargers
Postby SC V6 » Wed May 14, 2003 6:27 am
as far as extra gauges go.., what did u people choose to do? WHere did you put your S-Afc for example... im curious.. im thinkin im goin to get a supercharger in the next week... so im asking
thanks
scott
SC V6
Postby RayCarlo » Wed May 14, 2003 6:50 am
Hey Scott,
congrats on the supercharger, your gonna love it, back to the topic, on my solara i currently have the s-afc, trd boost gauge(10psi) and autometer air/fuel ratio gauge, but i think the air/fuel ratio gauge doesn't really serve much of a purpose except to look nice. i only got it because i got impatient waiting for an iol pressure gauge, and i was tired of driving around with one gauge on the duel gauge pod. From speaking to people and researching it seems that a boost gauge, EGT gauge, oil pressure gauge, and fuel pressure gauge are the best for monitoring purposes. So any of the previous would be good combinations. About where i mounted my S-AFC, i put that in the sunglass holder on the ceiling, that was the best place that i found for me, and it fits really well, the only modification i had to make was to take a little off of it so all the buttons on the S-AFC were accessible without problem. Well hope this helps
Ray
RayCarlo
Postby SC V6 » Wed May 14, 2003 7:06 am
thanks it helps a lot.. one more question.. well probably more than a few.. where is the best place to get these gauges.. and also, is installing them pretty easy??? did u or anyone do it themselfs?
thanks again
egt gauge? whats teh stand for?? i coulnd't figure it out.. sorry
is the eletronic boost gauge easy to use? if I was planning to change the boost regularly, would I stick with the EBC or get a manual boost controller?
SC V6
Postby adam2562 » Wed May 14, 2003 7:21 am
exhaust gas temperature
Adam - 99 V6 5spd 165k -SOLD
adam2562
Postby xXsolaraXx » Wed May 14, 2003 8:50 am
as for where to buy from and what brand you can run a search and will get tons of info on that. L8r moe :evilbat:
xXsolaraXx
Postby kondo » Wed May 14, 2003 10:20 am
I put my SAFC in my glove boc because I wanted it to be low key. There are pics on the 2nd page of my sounddomain page if you click on the www.
kondo
SolaraGuy StickerGuy
Postby Pat S » Wed May 14, 2003 3:56 pm
I built a digital boost into my gauge cluster and mounted the SAFC inside the dash behind the glove box to keep it out of sight.
Pat S
Postby Mole » Wed May 14, 2003 4:44 pm
slick place for the digi boost gauge
Postby xXsolaraXx » Wed May 14, 2003 4:48 pm
how accurate is it?
xXsolaraXx
Postby Hsakuragi » Wed May 14, 2003 10:00 pm
sorry..out of topic but is that a custom guage? Where you can get that without covering the security light?
Hsakuragi
Postby xXsolaraXx » Thu May 15, 2003 12:28 am
all u have to do is use this complex tool aka ...scissors! L8r moe :evilbat:
xXsolaraXx
Postby Pat S » Thu May 15, 2003 5:08 am
On the gauge covers, yes xXsolaraXx is right. Those where actually for manual and I cut out the PRNDL and the security light with a razor knife.
On the digital gauge. I ordered a digital gauge (round) and sending unit from dakotadigital.com for around $160. Then tore the gauge apart, removed the LCD panel and soldered a 6ft piece of wire to the LCD and to the board so I could remotely mount it. Then I trimmed off some plastic in an unused part of the cluster, cut a hole, made a small coverplate from the old gauge lense and epoxied everything together. Then I heated the black shroud with a heat gun and pressed it on a round wood handle to mold the plastic so you could see the gauge more clearly. I didn't make good contact on the lead for the decimal point so the gauge should say 0.0 instead of 00. It measures in increments of .2lbs and seems to be fairly accurate. With a 4lb pulley and no catback I was seeing up to 4.6lb with a 5.5 and a catback I see 5.6 Overall I reccomend the gauge from dakotadigital but don't reccommend the remote mount unless you are fairly good with a soldering pencil. I'm terrible and it took me many days with lots of frustration to get it even almost right.
Pat
Pat S
Postby PureNocence » Fri May 16, 2003 5:56 pm
I just got the TRD boost gauge...does the job 8)
PureNocence
