SolaraGuy.com • View topic - dogbone install
dogbone install
dogbone install
Postby rob96826 » Thu Dec 20, 2007 2:02 am
after replacing the oe bushings on the dog bone with superpro bushing, im getting vibrations through the steering wheel & a bit of cabin noise which was not there previously to the upgrade. also was the washer required to be installed??? i left it out since i could not get it to line up
rob96826
Re: dogbone install
Postby SleeperSolara » Thu Dec 20, 2007 7:02 am
rob96826 wrote:after replacing the oe bushings on the dog bone with superpro bushing, im getting vibrations through the steering wheel & a bit of cabin noise which was not there previously to the upgrade. also was the washer required to be installed??? i left it out since i could not get it to line up
Vibrations through the steerin' wheel??
Do you mean vibrations at idle??
There is suppose to be some vibrations through the cabin and steerin' wheel at idle if that's what you're talkin' about.
You don't have to use the washer.
I didn't use mine, i think that's washer is for if you have an S/C.
Postby Mole » Thu Dec 20, 2007 10:27 am
i never upgraded mounts, but if the mounts are upgraded aftermarket, things should be stiffer hence more feeling of the motor in the car.
Postby Paladin06Greg » Thu Dec 20, 2007 11:52 am
I was one of the first and have never had any problems.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby SleeperSolara » Thu Dec 20, 2007 5:31 pm
I haven't had any problems either.
I've love the Super Pro dogbone bushin'.
I also have FCA bushin's and P/S bushin's too. :D
Postby Paladin06Greg » Thu Dec 20, 2007 5:59 pm
DITTO - and the rear mount bushing. Only one of these produced..
SleeperSolara wrote:I haven't had any problems either.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby SleeperSolara » Fri Dec 21, 2007 7:01 pm
Paladin06Greg wrote:DITTO - and the rear mount bushing. Only one of these produced..
Which i envy you.
You're so lucky.
I really happy i was able to buy as many SuperPro poly bushin' i could get.
Now installin' the FCA and P/S bushin' is a different story. lol.
Postby TMMK Toy » Sat Dec 22, 2007 9:25 am
Ya, vibration is normal with stiffer mount mount bushings. Consider it a small tradeoff. Try driving a car with all solid mounts. Now that feels like Jenna Jameson's vibrator.
TMMK Toy
Postby SleeperSolara » Sat Dec 22, 2007 11:04 pm
TMMK Toy wrote:Ya, vibration is normal with stiffer mount mount bushings. Consider it a small tradeoff. Try driving a car with all solid mounts. Now that feels like Jenna Jameson's vibrator.
:lol:
Or havin' your back crunch everytime you hit a dip from poly RCA bushin's. lol.
