SolaraGuy.com • View topic - Building up the I4
Building up the I4
Building up the I4
Postby DjNoRhythm » Thu Dec 27, 2007 12:43 am
Greetings,
Anyone have any links to venders who offer performance parts for the I4?
I know that the V6 has the supercharger and I would go get one of those, but I like my car and only want a bit more for running the Portland Oregon freeways.
Thanks
DjNoRhythm
Postby woa_its_j3ff » Thu Dec 27, 2007 12:59 am
go custom turbo if you have the $$$.
Postby i20solara02i » Thu Dec 27, 2007 1:51 am
it depend what's i4 you have. if you have the 5sfe then you could try to get the rippmodd supercharger. if you have the 2azfe you can piece up parts from the scion tc, and use it for your car.
i20solara02i
Postby DjNoRhythm » Thu Dec 27, 2007 2:52 am
I have no idea what I have other than it is an 01 Solara SE.
How can I tell the difference between engines?
DjNoRhythm
Postby DjNoRhythm » Thu Dec 27, 2007 2:54 am
i20solara02i - What body kit is that on your car. That looks great.
Thanks
DjNoRhythm
Postby woa_its_j3ff » Thu Dec 27, 2007 2:57 am
^ custom. diff parts from diff kits, but molded and stretched to his liking.
Postby SdeA » Thu Dec 27, 2007 3:38 am
DjNoRhythm wrote:I have no idea what I have other than it is an 01 Solara SE.
99-01 model is 5S-FE
02-03 model is 2AZ-FE
SdeA
Postby Ruski » Thu Dec 27, 2007 9:51 am
DjNoRhythm wrote:i20solara02i - What body kit is that on your car. That looks great.
Thanks
Custom Wide body :wink:
if im correct the 01 i4 is the 5sfe engine, correct me if im wrong
Thanks
Postby CamryOnBronze » Thu Dec 27, 2007 10:43 am
IMHO, I have a 5sfe camry, and quite honestly- if you want more power, your best bet would be to swap for the v6. There isnt much potential to build that motor reliably, even with a large bank roll. Thats just my opinion though, I know some celica guys have built decent 5sfes...
Postby Jai_Jai_Binks » Thu Dec 27, 2007 5:56 pm
I am a 5sfe guy...why I got a solara was cus of 5sfe, my last 5sfe lasted forever - hence it was time for another 5sfe.
the v6 is always the answer to sg folks...its cheaper, but to answer your question: research celica and mr2 forums.
Postby CamryOnBronze » Thu Dec 27, 2007 6:36 pm
im not denying it lasts forever, im rocking 173k miles on mine, but it sure isnt the best choice for more power- especially not through boost.
Postby i20solara02i » Thu Dec 27, 2007 8:55 pm
Thanks
thanks for the comment. if you want to check out more pics it on this link http://www.solaraguy.org/viewtopic.php?t=22809
but if you want some decent amount of hp n don't want to do the motor swap. the rippmod s/c should give you a good pull.
ya alot of the guys would say go w/ the v6. i would say you do a 3sgte swap. around the same price range. give you more power depending what version 3sgte, it's turbo, more aftermarket parts, iron cast. but that's what i would do.
i20solara02i
Postby DjNoRhythm » Thu Dec 27, 2007 9:08 pm
Thanks
What did the 3sgte come out in??? What models were turbo? What is involved in the swap?
I am an old school hot rodder who is new to this game so please forgive my ignorance.
Many Thanks,
DjNoRhythm
Postby TadS » Thu Dec 27, 2007 9:38 pm
The Ripp header is a good piece for the 5S-FE, or if you have good skill you can swap the cams. Really the sky is the limit, but doing a 5S-FE is not cheap. You can do all the normal stuff, and get some decent gains, but it will cost you.
TadS
Users browsing this forum: Google [Bot] and 31 guests
