SolaraGuy.com • View topic - y-pipe w/o cat~
y-pipe w/o cat~
y-pipe w/o cat~
Postby shocar4 » Thu Dec 27, 2007 11:56 am
i have been reading some different post on here about custom y-pipes and high flow cats and the power that is unharnessed~ what can i expect performance and noise wise, if i get a custom y-pipe made (from my muffler man) and no cat (of course i will have to run an o2 simulator) or a magnaflow cat like dawgs has......right now i am running 4psi with a sri and the trd exhaust! jim's fuel upgrade is on the way! yeahh!!
shocar4
Postby Akfahad » Thu Dec 27, 2007 5:05 pm
i believe it's been discussed before in terms of power gains with a high flow cat v. no cat. the benefits of running no cat was like a 1hp difference between the two. altough, running no cat will make the exhaust somewhat louder too, wasn't really worth it to me so i threw on a high flow cat.
Postby shocar4 » Thu Dec 27, 2007 6:55 pm
how much does a high flow cat go for! i know that dawgz has a magnaflow high flow that looked real nice!
shocar4
Postby Midias » Thu Dec 27, 2007 8:08 pm
You can get a universal cat off ebay fairly inexpensively. If you are looking for a good highflow cat and the stuff to make a custom system I can help you out. Just post back with specific questions and I will answer them. BTW I am the one who made up Akfahads and Dawgs cat. I got lucky with dawgs tho trying to angle the flange to match a picture he sent was a bitch.
Postby Dawgz » Thu Dec 27, 2007 9:37 pm
^ yep!
If you can talk Midias into making another one, he makes great cats. He'll even work with you to get the correct angle...he's a master at his craftsmanship!
Thanks agian Midias.
Postby shocar4 » Thu Dec 27, 2007 9:44 pm
what kinda of price is it midias for what you did for dawgz?
shocar4
Postby 20SoLaRa02 » Thu Dec 27, 2007 11:48 pm
to jump in on this, i believe dawgz was using the datsypipe if i'm not mistaken. if you are really interested in this setup, let me know because i have one for sale. Its brand new wit the test pipe, so midas can make you a high flow :).
good luck,
Michael
20SoLaRa02
Postby Mole » Fri Dec 28, 2007 12:41 am
noise will be louder... bigger pipe/better flow = louder noise.
be prepared to gain a good 20-30 whp. but don't follow the stock design.
Users browsing this forum: Google [Bot] and 31 guests
