SolaraGuy.com • View topic - Aftermarket electronics only powered when key is at "On
Postby Guest » Fri May 16, 2003 4:21 pm
I am trying to locate a certain product.
I have several aftermarket electronics installed in my Solara that are connected directly to the vehicle's battery. However, I tend to forget that they are on when I leave the vehicle, and as such, the battery dies. I am looking for a device that will connect between my electronics and the battery so that the devices only turn on when the vehicle's key is in the "On" (Or "Acc") position. I have seen this before but cannot recall where I saw it. Does anyone know who carries this and what it is called?
I have checked with AutoZone (who says they've heard of it, but don't carry it) and Car Toys (who has also heard of it, but wasn't sure if they carried it. They told me to email their online customer service, so I'm still waiting on that).
Thanks.
Guest
Postby Gunman » Fri May 16, 2003 4:40 pm
what kind of equipment are you talking about here? A simple relay is all you need as long at the current draw isnt to excessive.
Gunman
Postby Guest » Fri May 16, 2003 4:56 pm
Actually this equipment can draw some relatively high amperage. There are about 4 devices, and the most taxing one can draw up to 20amps depending on how it's used.
Guest
Postby Gunman » Sat May 17, 2003 5:55 am
ok so you can use a relay on the negative side to flip on and off with the iginition
Gunman
Postby Guest » Mon May 19, 2003 1:46 pm
Ok. What type of relay?
Guest
Postby Gunman » Mon May 19, 2003 8:00 pm
a simple, single pole double throw Bosch relay will do, perhaps a few might suit your purpose better one for each component. My only question is do these devices require memory and settings?
Gunman
Postby Yanks0114 » Tue May 20, 2003 10:59 am
If they were a little lower current, couldn't you also tap the accessory (Red Wire) from behind the headunit. Also you could tap in the fuse block. You would be looking for something like the windshield wipers which shut off with the car.
