SolaraGuy.com • View topic - OFFICIAL GEN 1-1.5 AFTERMARKET PARTS LISTING
Postby lilm » Sun Mar 15, 2009 5:03 pm
this is not a q/a type thread please post it in the aftermarket section
edit for p/n
the thermostat PTR04-00127 for 2.2l? dunno if they are interchangeable
trd clutch assembly? PTR15-21051-60 (http://www.toyotaparts4u.com/solara-trd ... p-363.html)
trd shifter knob
sexy shifter knob PTR04-00000-05 64.99 at (http://www.toyotaparts4u.com/solara-trd ... p-368.html)
ball shifter knob PTR04-00000-06 27.99 at (http://www.toyotaparts4u.com/solara-trd ... p-369.html)
trd oil filter PTR14-00000-04 13.99 at (http://www.toyotaparts4u.com/solara-trd ... p-366.html)
trd differential PTR39-21070 1299 at (http://www.toyotaparts4u.com/solara-trd ... p-362.html)
Quaife differential(maybe the same im not sure)(no p/n sorry) 1399 at (http://www.horsepowerfreaks.com/perform ... ferentials)
whew lol
lilm
Postby Mr_Krispy1183 » Wed Apr 01, 2009 11:08 pm
Midias, please add to suspension section.
Ultra Racing -available in the US through Next Gen Tuning
4-point lower tie brace (part# UR-LA4-366)
$149 + shipping
Rear lower member brace 2 pc. (part# UR-RL4-614P)
*I'll add price once confirmed*
Postby Midias » Thu Apr 02, 2009 5:15 am
Some updates made
Postby Midias » Fri Apr 10, 2009 10:30 am
Update to Ignition section
Re: Official Gen1-1.5 Aftermarket Parts Listing
Postby evilkazuya1 » Thu Jul 09, 2009 2:24 am
Midias wrote:I think this should be a sticky
TRD Section
TRD (www.trdusa.com) or PM NVDIS1 or (www.trdsparks.com):
Front Strut Tower Brace (Discontinued)
Supercharger 3.0l V6 (Discontinued)
Rear Sway Bar (PTR06-06990-10)
Sports Muffler (PTR19-06990-03)
Lowering Springs (1.2 / 1.4) (PTR07-06990-SL)
Air Filter 2.2L, 2.4L, 3.0L I4 and V6 (PTR05-06990-01)
Cleaning kit for all TRD air filters (PTR05-00000-CL)
TRD Radiator Cap (PTR04-00000-02)
TRD Thermostat 2.2L (PTR04-00127)
Short Shifter
Short Shifter Section
TWM (http://www.twmperformance.com)
Short Shifter - 2" height reduction - 35% throw reduction
Ralco RZ (http://www.ralcorz.com/)
Short shifter (914938)
K&N Oil Filter Section
K&N (www.knfilters.com):
Oil Filter 2.2L, 2.4L I4 (HP-1003)
Oil Filter 3.0L V6 (HP-1002)
Oversize Oil Filter 3.0L V6 (HP-2009)
HEY WAS UP
i want to know what size of after market steering wheel fits in a 2000 solara i had a momo monte carlo steering wheel and i didnt fit if u guys can help
Ignition Section
Ignition Solutions (http://www.okadaprojects.com/usa/home.htm)
High Powered Coils
2.4L 2AZ-FE Coil-Over Plug Direct Fit (PD4003701R)
Magnecor (www.magnecor.com)
Wires 8mm 7mm 8.5mm
3.0 V6 60212 67212 65212
2.2 I4 40298 47298 45298
NGK (www.ngksparkplugs.com)
NGK IX iridium 3.0L V6 NA (BKR6EIX-11)
NGK Premium wire set 3.0L V6 (TE65)
NGK IX iridium 2.2L I4 (BKR6EIX-11)
NGK Power Cables 2.2L I4 (10T)
NGK Premium wire set 2.2L I4 (TE58)
NGK IX iridium 2.4L I4 (BKR6EIX-11)
Weapon R (www.weapon-r.com):
Ignition Equalizer Kit 2.4L I4 (960-113-101)
Misc Performance Section
Over Bore TB (http://www.proflowdesign.com/tbtoy.html)
Toyota Solara 1MZ-FE 3.0L V6
Price $175.00
UNORTHODOX (http://www.unorthodoxracing.com/)
ULTRA S CRANK PULLEY 2.2L (021210102)
URD (http://www.urdusa.com/)
Crank pulley 3.0L V6 (discontinued)
Throttle Body Spacer (www.hubcapsplus.com)
Helix Power made for Tacoma 3.4L V-6 fits 3.0 V6 (SPE-34055)
Use coupon code HELIX
Requires 2 new bolts from home depot. You need 2 M8 X 1.25 70mm and 2 M8 Washers for top. For the bottom use the 90 mm screws that came with the kit and 2 washers under each.
Throttle Body Spacer (ebay.com)
OBX made for Scion TC 2.4L I4 fits 2.4 I4 (SPE-97220)
Jet ECU upgrade (http://www.jetchip.com)
99-06 Solara All Engines All Trans (65003)
KNOCK SENSOR UPGRADE (http://www.atsracing.net)
http://www.atsracing.net/ats_racing_knock_sensor.htm
Replacement Sensors Wells SU 121 or Borg warner S 8803
(1997 Camaro 5.7L knock sensor)
Unicersal Oil Catch Can (www.ebay.com)
For all engines
Oil Catch Can LINK
Intake Section
Note on intakes CPE is the best choice as far as power is concerned. No one makes a true CAI and the ebay intake is crap.
eBay (www.ebay.com)
Ebay Generic 2.2L I4
Intake 3.0L V6 DON'T BUY THIS
Custom Performance Engineering, CPe (www.cp-e.com):
Short Ram Intake With ECU upgrade MAFci Kit, 3.0L
Average gains of 14.7 wheel hp and 15.4 wheel ft lbs.
Peak gains 17.5 wheel hp and 20.1 wheel ft lbs.
Larger K&N filter upgrade for CPE
K&N Filter Number: E-0773
Secret Weapon Intake System 2.2L I4 (305-120-101)
Dragon Intake System 2.2L I4 (805-120-101)
Secret Weapon Intake System 2.4L I4 (305-144)
Dragon Intake System 2.4L I4 (805-144)
Secret Weapon Intake System 3.0L V6 (305-129-101)
Dragon Intake System 3.0L V6 (805-129-101)
Injen (www.injen.com):
Short Ram Intake 2.4L I4 (IS2025BLK or IS2025P)
Short Ram Intake 3.0L V6 (IS2030BLK or IS2030P)
Short Ram Intake 2.2L I4 (IS2020P)
Air Filter 2.2L, 2.4L, 3.0L I4 and V6 (33-2219)
Typhoon Kit 2.4L I4 (69-8609TTK)
6.4 HP @ 5600 RPM
Air Filter 3.0L V6 (33-2145-1)
OBX (www.obxracingsports.com, ebay)
Intake 2.75 inch 3.0 V6 (OB10353)
Exhaust Section
JP Performance (http://jpheadersexhaust.com)
JP Headers 3.0L V6 (JP-1MZFEhd)
JP Headers 2.4 I4 (No part number listed call)
JP 3 Inch Cat-Back (JP-1MZFEScb)
Ebay Headers (www.ebay.com)
Unknown manufacture
3.0 V6 with test pipe
Greddy (www.greddy.com)
Greddy Evo 2 Cat-Back 3.0L V6 (GRD-10116601) Discontinued
Apexi (http://www.apexi-usa.com/)
APEXi World Sport Cat-Back 3.0L V6 (104-KT02) Discontinued
OBX Racing (www.ebay.com)
For Camry and Solara V6 3.0L 3" pipe
Headers for 99-02 Solara uses resonator instead of a converter.
Header for 97-01 2.2 camry could be adapted for solara.
V6 Header install
http://www.solaraguy.com/viewtopic.php?t=45220
JIC-Magic (www.jic-magic.com)
All Engines
DE Type 1 ST Catback (MCV20D1-ST)
DE Type 1 Sus Catback (MCV20D1-SU)
Megan Racing (http://www.meganracing.com)
All Engines 2.5 inch piping
OE performance style non fart cannon ( MR-CBS-TSO99V6OE)
Drift Spec Z N1 style muffler (MR-CBS-TSO99V6DS)
Suspension Section
Eibach (www.eibach.com)
Lowering Springs All Engines (8258.140) (-1.6" / -1.6")
Tein (www.tein.com/)
Tein S Tech Lowering Spring All Engines (TEN-SKL16-AUB00) (-1.7" / -1.4")
Tein Coilovers (DSL16-KUSS2)
Lowering springs all engines (MR-LS-TCA97) ( 2" Front, 1.7.5-2" Rear)
KYB (www.kyb.com)
GR-2 All Engines
Right Hand Front (334245) Rear (334133)
Left Hand Front (334246) Rear (334134)
Tokico (www.tokicousa.com)
Tokico HP All Engines
Right Hand Front (TOK-HB3185) Rear TOK-HB3182)
Left Hand Front (TOK-HB3184) Rear (TOK-HB3181)
JIC-Magic(www.jic-magic.com)
All Engines
Front Strut Tower Bar aluminum (OAS-MCV20-F)
Front Strut Tower Bar Carbon Fiber (TBA)
FLT-TAR Coilover System (MCV20FLTA2)
FLT-FAS Coilover System (MCV20LFLTA1)
Whiteline (www.whiteline.com), (http://www.globalperformanceparts.com)
All Engines
Sway Bar Front (BTF38) 24mm
Sway Bar Rear (BTR39) 20mm
Front Springs (73119)
Rear Springs (78600A)
Strut Tower Brace (KSB508)
Energy Suspension (www.energysuspension.com)
99-03 All Engines
Front End Control Arm Bushing Set (8.3117)
Rear End Control Arm Bushing Set (8.3118)
Front Sway Bar Frame Bushings 18mm (9.5122)
Front Sway Bar Frame Bushings 19mm (9.5123)
Rear Sway Bar Frame Bushings 16mm (8.5120)
Ultra Racing (www.nextgentuning.com)
99-03 All Engines
Transmission Section
ACT (www.advancedclutch.com)
ACT Modified Street Clutch Disc 3.0L V6 (ACT-2000604)
ACT XTreme 4-Pad Solid-Center Race Clutch 3.0L V6 (ACT-4236007)
ACT XTreme 6-Pad Solid-Center Race Clutch 3.0L V6 (ACT-6236007)
Exedy (www.exedyusa.com)
OEM Replacement clutch
1999 - 2001 SOLARA BASE L4; 2.2L; Gas 5SFE (16073)
1999 - 2002 SOLARA BASE V6; 3.0L; Gas 1MZFE (16062)
Fidanza (www.fidanza.com)
Lightweight Flywheel V6 Manual ONLY 1MZFE (130881)
evilkazuya1
Postby 1gSE » Thu Jul 09, 2009 5:33 am
evilkazuya1 wrote:[HEY WAS UP
lilm wrote: this is not a q/a type thread please post it in the aftermarket section
Solara-M62 @ 5.5psi
1gSE
Postby Inverted » Tue Aug 25, 2009 3:00 pm
What's the difference between PTR06-06990-10 and 00602-48830-010??
Both 'rear sway bars' by TRD. Hopefully I got the right one by ordering PTR06-06990-10
Mike
Inverted
Postby Midias » Tue Aug 25, 2009 4:05 pm
Inverted wrote:What's the difference between PTR06-06990-10 and 00602-48830-010??
Mike
Taking a guess the PTR number is an internal part number from the site you bought the product while the other is toyota's part number.
Postby Inverted » Tue Aug 25, 2009 6:41 pm
Midias wrote:Rear Sway Bar (PTR06-06990-10)
I think you're right, except maybe vice-versa =)
Inverted
Postby Akfahad » Wed Aug 26, 2009 7:53 am
Midias....didn't see it on there...could put under misc. performance parts....
http://www.snowperformance.net/products.php?p_cat=302
Postby GreenSolara01 » Wed Aug 26, 2009 6:51 pm
doesn't the 1MZ hae a MAF ?
How would this meth kit work on laras?
GreenSolara01
Postby lilm » Wed Aug 26, 2009 6:53 pm
THIS IS NOT A Q/A TYPE THREAD!!!!!!!!
lilm
Postby 1gSE » Mon Oct 26, 2009 2:27 pm
Denso fuel injectors
pt #23250-46030 (330cc?)
pt #195500-2010 (460cc)
Solara-M62 @ 5.5psi
1gSE
Postby epinkiert22 » Mon Mar 22, 2010 8:42 pm
Could you post pictures of the Front strut tower brace that you have
epinkiert22
Re: OFFICIAL GEN 1-1.5 AFTERMARKET PARTS LISTING
Postby EkiMucH » Fri Aug 27, 2010 12:16 am
Pretty much new around here, but I came across this and wanted to share with the group. Unless I missed it somewhere on there, I apologize.
http://www.meganracingperformance.com/9903-toyota-solara-stainless-steel-header-down-pipe-p-89970.html
EkiMucH
