SolaraGuy.com • View topic - what tires should i get??
Postby randy_1651 » Tue May 20, 2003 1:06 pm
i was woundering which tires i should get to replace my stock 16" potenzas any suggestions :D
randy_1651
Postby Mole » Tue May 20, 2003 5:09 pm
im assuming you want the tires that people with rims have?
just stick to a reasonable tire out there. rolling on stock wheel tire dimensions will not get you much performance gain. however if you feel like grabbing a tire like mine, (180treadware WOOT!) by all means go right on ahead.
here's a short list of good tire brands to look into
Pirelli
Yokohama Avs Sport
Kumho 712's?
i have heard badnews with Nitto 450's, however i had them before and never ran into any trouble.
Postby richcali1@email.com » Tue May 20, 2003 6:15 pm
Toyo Proxy
Kuhmo
Michelin Pilot
All in all go with one that fits your weather conditions.
richcali1@email.com
Postby xXsolaraXx » Wed May 21, 2003 8:37 pm
use search function! L8r moe
xXsolaraXx
Postby happy_aggies » Thu May 22, 2003 7:53 am
I once used Nankang, it's cheap n good. :D
Kumho is a bit noisy.
happy_aggies
Postby TXSolaraSLE » Fri May 23, 2003 12:11 pm
i've had Michelin MXV4 XSE Plus tires and Yokohama Avid H4s...both were great for ride quality and tread noise. I think the michelin's held up better on tread life, but they're also almost twice the yokohamas. You could always go to tirerack.com and search for tires that fit. they have reviews, specs, roadtests..everything you could need to make a decision.
brian
'99 Black Solara SLE
18" Mille Miglia Evo5
Yokohama AVS ES100
Indiglo Gauges
Kicker KSR100
K&N Filter
Xenon Headlights & License plate bulbs
TXSolaraSLE
Postby dbanker » Fri May 23, 2003 6:12 pm
I'm on Michelin Pilot Sport A/S (225/40/18) right now and I absolutely love them so far. Don't know if they'd be worth the $$ on 16's though.
Doug
dbanker
Postby soniasolara » Mon May 26, 2003 7:48 pm
I was planning on getting Dunlop Sport A2's when my stock Potenza RE92 (horrible tires!) wear out, which unfortunately may be sooner rather than later. Whatever you decide, go ahead and use the "search" function to look for other tire discussions.
Also, check out tirerack.com for user ratings, and you may decide to order tires from them and have them shipped to a local installer.
I suspect being from Texas you will have no worries about snow, so that makes getting performance tires easier.
2001 SE, 5S-FE auto, 1C4
K&N stock replacement air filter
Kumho ECSTA HP4 716
soniasolara
Users browsing this forum: No registered users and 74 guests
