SolaraGuy.com • View topic - Instrument cluster removal
Postby Astro » Wed May 21, 2003 12:33 pm
I was wondering if the two screws on top of the bezel are suppose to be on so tight. I tryed to take them off, but I ended up chipping my craftsman screwdriver! Any suggestions?
Postby Mole » Wed May 21, 2003 1:20 pm
get another screwdriver. becareful, dont strip those screws, if you do, then it will be a royal pain in the arse to take them out.
just make sure you are in the grooves and put a good amt of pressure on it. first time is always a b*tch
Thanks
Postby Astro » Wed May 21, 2003 1:21 pm
I thought Craftman tools were tough!
Re: Thanks
Postby Yanks0114 » Wed May 21, 2003 4:03 pm
Astro wrote:I thought Craftman tools were tough!
Should have a lifetime gaurentee on it. Return it. You can easily strip a screw drive if you use the wrong size tip
Postby FLASH » Wed May 21, 2003 7:04 pm
I too had problems getting those screws out. In the end, I stripped them and never got them out. I hope you dont have the same problem, because I'm now 'royally screwed'
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby 99solarai4 » Wed May 21, 2003 8:40 pm
It's not the size of the screwdriver, it's the angle of the dangle.....or something like that.
Those screws are really tight. Try different angles to get the best bite with the screw driver.
'99 Solara SE i-4
Back to Stock
99solarai4
Postby Mole » Wed May 21, 2003 9:18 pm
angle or not, it should be at 90 degress of the screw. in other words it should be lined up with the screw straight.
Postby kronos98 » Wed May 21, 2003 11:17 pm
yeah, like someone said, make sure you put enough pressure on it and turn slowly.
after the first few times, it's really easy to open. actually, i didn't tighten mine super tight after i opened it, so i don't have any trouble anymore :D
kronos98
Postby Hsakuragi » Thu May 22, 2003 1:55 pm
Ya, it won't be tight anymore after the first time.... Just make sure u have tons of screwdrivers to try.
Hsakuragi
Postby krook » Thu May 22, 2003 4:06 pm
best bet. get a STUBBY RATCHETING screwdriver. it's the only way to ensure the right amount of pressure, rotation, and angle.
return it after your done.
krook
