SolaraGuy.com • View topic - Upgrading my ignition system???
Postby AguinaldoHomes Inc » Sat Feb 02, 2008 12:56 pm
Im in the process of upgrading my ignition system now and I'd like to know if you guys can recommend a good manufacturer for the following:
Spark Plugs
Spark Plug Wires
Ground Wires
Battery
Alternator
Thanks,
Mark
Mark Aguinaldo
Aguinaldo Homes, Inc.
(908) 220-3692
aguinaldohomes@yahoo.com
AguinaldoHomes Inc
Postby Turbosolara » Sat Feb 02, 2008 1:10 pm
for what engine?
spark plugs: Denso Iridium
wires: oem is good enough, i dont think you can feel much difference. but if you insist, i heard Nology is good
Ground wires: make your own with stereo power cables, i am not sure if there is a kit for solara
battery: according to consumer report, costco kirkland brand is the best bang for the bucks. other peopel used optima. i heard some good review from voltpreak battery, which is only 3lb. http://www.voltphreaks.com/
alternator, i have no clue. do you have upgraded stereo?
Postby AguinaldoHomes Inc » Sat Feb 02, 2008 1:11 pm
03 Solara SLE V6 Motor!
Mark Aguinaldo
(908) 220-3692
AguinaldoHomes Inc
Postby Chinky420 » Mon Feb 04, 2008 1:02 pm
as for the alternater, i believe that the sienna or tundra 180amp is a direct bolt on fit for our rides. hit the search function to double check what years and model, and then hit the junk yard to pick on up cheaper
Chinky420
Postby Eye8Pussies » Mon Feb 04, 2008 6:52 pm
highlander w/ tow package
Postby shocar4 » Mon Feb 04, 2008 7:56 pm
i just upgraded to magnecor wires because i am supercharged! i have an oem set of plug wires that have just over 20k on them if you are interested!
shocar4
Postby 99V6solaraSE » Mon Feb 04, 2008 9:14 pm
Magnecors or the NGKs spark plug wires are the only ones i know of that they make for the solara. I cant really tell the difference in performance though.
As for ground wires, if you do a search theres a lot of different opinions.
There are some universal kits out there. And some say its not worth it and do it themselves. They just buy the same kind of wire found in those kits.
As for alternators, what are the advantages of having those alternators?
99V6solaraSE
Postby AguinaldoHomes Inc » Tue Feb 05, 2008 7:32 am
Anyone here ever dealt with mralternator.com?
Mark Aguinaldo
(908) 220-3692
AguinaldoHomes Inc
Postby Midias » Wed Feb 06, 2008 12:30 pm
AguinaldoHomes Inc wrote:Anyone here ever dealt with mralternator.com?
Their prices are not bad but the highlander alternator is comparable and half the price.
