SolaraGuy.com • View topic - 19" Rim Tire Fitment
Postby tweazy » Tue Feb 05, 2008 11:50 am
Hi,
This is a repost from Toyota Nation and though I'd ask here as well.
I just bought a used set of 19"x8.5" RH C5 rims and was wondering what tire size would fit best. It has a +38 offset and am planning to use spacers (Not sure what size yet). I have JIC Magic FLT-A2 coilovers in my 2000 Solara.
Which tire size should I get?
235/35/19
245/30/19
245/35/19
Here are my thoughts on these sizes.
The 235/35/19 would probably work best since the actual thread is thinner than the rim's width and the sidewalls stretched inward. Less likely to rub.
The 245/30/19 would cover the width of the rim better with thinner sidewalls. No stretching required and would probably give the same over all hight as the stretched 235/35. Will probably need to roll fenders.
The 245/35/19 Largest of the 3 specs - almost 1 inch taller than a 245/30/19. Might just be too big.
Any help would be greatly appreciated!
tweazy
Postby ---CAMRAZY--- » Tue Feb 05, 2008 12:02 pm
235/35/19, 2-5mm spacer for the rear to clear the CO and you are going to have to roll your fender.
Didn't you get my pm back?
Postby tweazy » Tue Feb 05, 2008 12:46 pm
Thanks. You just answered my main concerns regarding fitting these rims.
Did you use spacers for the front as well?
I never got your PM.
tweazy
