SolaraGuy.com • View topic - uPDATE ?? TRD Revos vs diff size Tires 45 VS 55
Postby LatinUSMC » Tue Feb 05, 2008 4:17 pm
i have the TRD REVOS i wanna make sure these fit:
215/55/17 Toyo Proxes
215/55/17 Hankook Ventus
i used it http://www.rims-n-tires.com/rt_specs.jsp
but i still didnt figure it out: HELP
i currently have 215/45/17 in the front and 235/45/17 in the rear/thats how i bought them...
will 215/55/17 fit??????? SAfely/ :oops: :oops: :oops: :oops:
2nd question..how do i know when its time to replace my current khumos.(the penny test?)
LatinUSMC
Postby dvdchris45 » Tue Feb 05, 2008 5:15 pm
go to the bottom right of the page where it says "size comparer" and put in all the info of your current tire and rim size and what you want to run and see what it says..
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby Eye8Pussies » Tue Feb 05, 2008 6:52 pm
should be 215/50
Postby LatinUSMC » Tue Feb 05, 2008 7:25 pm
thanks :lol:
LatinUSMC
Postby LatinUSMC » Tue Feb 05, 2008 8:19 pm
dvdchris45 wrote:www.rims-n-tires.com
i current ly have 215/45/17 in the front and 235/45/17 in the rear/thats how i bought them...
LatinUSMC
Postby CamryOnBronze » Tue Feb 05, 2008 8:34 pm
its too much sidewall... I dont know if it will rub, but your speedo will be off. Just get the right sized tires.
Postby SleeperSolara » Wed Feb 06, 2008 12:09 am
i think 215/55/17 should be fine.
Just run 225/45/17. :wink:
Postby LatinUSMC » Wed Feb 06, 2008 9:22 am
is that what your rolling on? 225/45/17? :o 8)
LatinUSMC
Postby SleeperSolara » Wed Feb 06, 2008 9:48 am
LatinUSMC wrote:is that what your rolling on? 225/45/17? :o 8)
A hell yeah. :D
Postby tweazy » Wed Feb 06, 2008 10:02 am
TRD Revo rims originally come with 225/45/ZR17 Toyo Proxies Plus 1 tires
tweazy
Postby LatinUSMC » Wed Feb 06, 2008 11:11 am
thank you^^^^^ thats what i thought, so 235 is a lower profile right? and 215 is biggger not as thin. more like stock.right? so im not doing too bad w 235/45/17 8)
LatinUSMC
Postby SleeperSolara » Wed Feb 06, 2008 11:22 am
LatinUSMC wrote:thank you^^^^^ thats what i thought, so 235 is a lower profile right? and 215 is biggger not as thin. more like stock.right? so im not doing too bad w 235/45/17 8)
235 is a wider profile for the width of the tire.
215 is a lower width profile of the tire.
Example: - 225 - is the width of the tire that meets the pavement.
- 45 - is the sidewall width that the tire meets the rim.
- 17 - is the size of tire that fits on the what size your got.
You could go wit 235... I would like to see what that looks like on the Revo rims.....
Personally i would stick wit 225....
Postby LatinUSMC » Wed Feb 06, 2008 11:54 am
^^^^^ill post pics of my current 235 when i get home tonight 8) i will most likely go w the same you have 225..if thats what they came with, thats why i broke the clip, because the spacers eliminate that gap where i can insert the ringbar... heard of these: Avon Tech RA in 225/45/17 some guys selling.
LatinUSMC
