SolaraGuy.com • View topic - No more resonator for me (video UPDATE 3_16_08)
Postby Midias » Thu Feb 07, 2008 9:49 am
Well after about 4 years of salt and other winter crap my non stainless resonator broke well actually snapped at the coupler. My plan is to build a full stainless system that would be universal for gen 1-1.5 to be a mid pipe for the TRD muffler. So I decided to go the cheap route to fix it for now using piper from autozone and 2 muffler tips to make the S bend required but I thought I would post about the resonator vs no resonator experiences I am having.
First I would like to state my resonator was a louvered type not perforated so it is a lot more restrictive than the kind I will be using on the new system and the kind I have recommend to people on the board. I was young and stupid and did not know the difference.
The power difference over the louvered resonator is noticeable but I do not believe this would be the case with a straight through perforated resonator. As for sound level it is hard to say because I drove around with a cracked resonator for so long I was use to the sound with an exhaust leak but I think it is a little louder than with a resonator. The actual sound its self is about the same inside the cabin but with the window down or outside the car it is a different story. The sound is much more raspy than before the borla muffler still sounds good but the quality is a bit more tinny now. All together it is not unpleasing and I will get a video clip so I can compare it to the stainless exhaust this spring.
So if you want pics or have a question just ask and I will get them for you just thought I would post my experiences.
Before with resonator (I like this one better)
http://s86.photobucket.com/albums/k93/m ... 0_0095.flv
After without
http://s86.photobucket.com/albums/k93/m ... eb04af.flv
Postby woa_its_j3ff » Thu Feb 07, 2008 11:02 am
Hrmm wonder what the sound is like for you now :D
clips?
keep us posted!
Postby Solorange » Thu Feb 07, 2008 4:55 pm
I can second that. I cut the resonator off my car and welded a piece of straight pipe in for a short while. And I have a TRD muffler. I personally think the sound is the same its just a little more pronounced. It doesnt make the car too loud either. I personally want the sound to be a little louder than the TRD, but not too loud. Without the resonator it brings it to the level I wanted. My only problem was that when I welded the pipe in the heat pulled it a little on me changing the angle. This caused my muffler tip to butt up against the unibody of my car and everytime I hit a bump you could hear it clunk. The clunking got to me and Dat so graciously sold me his center section so now I got the stock resonator again.
Postby Midias » Thu Feb 07, 2008 4:58 pm
woa_its_j3ff wrote:Hrmm wonder what the sound is like for you now :D
clips?
keep us posted!
I will try to get a video but the only problem is comparing it to current vids I have is I think I may have had a small hole in my exhaust when my previous videos were shot making it louder and slightly more raspy. It will be interesting to compare them. I think the best comparison will be when I make my full stainless setup in a month or two. My current setup was the easiest and cheapest fix at the time only 20 bucks to replace the middle section.
Postby Midias » Sun Mar 16, 2008 3:13 pm
Updated links on first post
