SolaraGuy.com • View topic - Keyless Entry
Keyless Entry
Keyless Entry
Postby Orefus » Thu Feb 07, 2008 8:08 pm
My car didnt come with keyless, and now in winter my locks are starting to freeze. I was thinking of buying one of these http://cgi.ebay.com/REMOTE-CAR-START-ST ... dZViewItem
Think they would do the job?
Orefus
Postby Brettboy » Thu Feb 07, 2008 9:35 pm
Mine didn't come with keyless entry either. I bought one similar off of ebay and had an electronics store install it for about 120.00. I've been pleased thus far. It even came with a nice LED light they installed. Let me know if you have any questions about it.
99' SE V6 Black Metallic
Customized grille, 18 inch ADR rims, Injen intake, K&N Filter, 20% tint, Iggee custom seat covers, teins, tokicos
Brettboy
Postby BlKSo|aRa » Thu Feb 07, 2008 10:06 pm
u can get viper alarm with remote for 150 installed.
BlKSo|aRa
Postby DrLove » Thu Feb 07, 2008 10:07 pm
If your car has the "security" red LED on the gauges, then you already have the possibility of keyless entry. My car didn't come with a remote, but for $15 on ebay my car now LOCK and UNLOCK with the remote.
Mazda 6 2010 6 speed black GS
DrLove
Postby wekillyou » Thu Feb 07, 2008 10:24 pm
DrLove wrote:If your car has the "security" red LED on the gauges, then you already have the possibility of keyless entry. My car didn't come with a remote, but for $15 on ebay my car now LOCK and UNLOCK with the remote.
how did you get it to work? i also would like keyless entry on mine.
wekillyou
Postby DrLove » Fri Feb 08, 2008 7:34 am
Just type "SOlara remote" on Ebay and you will find it. On the 99, you can't have the "trunk" button working.
Mine came brand new (not used like lot of remotes on Ebay) with instructions for $15.
that's the instructions that I did to make it work. It can take several try! Mine worked after 1h of trying..
1. Start with the following conditions:
a) Key is out of the ignition
b) Driver door is open (all other doors are closed)
c) Driver door is unlocked (other door locks don't matter)
2. Insert the key into the ignition (don't turn it) and pull it out.
3. Perform these steps within 40 seconds:
a)Using the power lock/unlock switch on the driver's door (with the driver's door still open and unlocked), perform 5 lock/unlock cycles starting with lock. A lock/unlock cycle consists of pressing the power lock switch, followed by pressing the power unlock switch on the driver's door panel. Use an even pace and try to go relatively fast.
b)Close, then open, the driver's door.
4. Perform these steps within 40 seconds:
a) Using the power lock/unlock switch on the driver's door, perform 5 lock/unlock cycles starting with lock, as you did previously.
b) Turn the ignition to "ON" (as far as you can go without cranking your engine), then back to "OFF".
c) Again, turn the ignition to "ON" (as far as you can go without cranking your engine), then back to "OFF".
d) Remove the key from the ignition.
5. Within 3 seconds, the power door locks should cycle (lock then unlock) automatically, indicating successful entry into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds:
a) Press the lock and unlock buttons on the transmitter (the remote) simultaneously for 1 second.
b) Immediately after letting go of the lock and unlock buttons, hit the lock button by itself and hold it for 2 seconds. Within 3 seconds, the door locks should cycle (lock then unlock) once indicating successful programming. If the door locks don't cycle, or cycle twice, repeat steps 6a and 6b, as this means the remote has not been accepted.
c) Repeat steps 6a and 6b for each transmitter that will operate the vehicle, including any old transmitters.
7. Close driver's door.
DrLove
Postby Orefus » Fri Feb 08, 2008 7:38 am
Mine has no red LED security light. I think it didnt come with it at all.
Can you guys recommend me some good buys for the keyless?
Orefus
Postby shocar4 » Fri Feb 08, 2008 7:52 am
Orefus wrote:Mine has no red LED security light. I think it didnt come with it at all.
check under the center console where your arm rests! i have a 99 also and the keyless entry control box if you have one is under that!
shocar4
Postby Orefus » Sun Feb 10, 2008 8:14 pm
Yeah, I dont have it. Care to recommend any good combos, and deals. I might be looking to get remote start with it.
Orefus
Postby poisonspider » Fri Feb 15, 2008 3:38 pm
soryr
2001 toyota solara
poisonspider
