SolaraGuy.com • View topic - is300 Rims
is300 Rims
is300 Rims
Postby Dawgz » Sun Feb 17, 2008 10:44 pm
Would they fit correctly on the gen 1 solara? Or would i need to buy spacers or whatever.
Anyone have any idea?
here's a picture if had for a while, i dono whos solara it is...but it looks real clean with the is300 rims...
Postby woa_its_j3ff » Sun Feb 17, 2008 11:12 pm
yes they will fit. a guy I know who used to be on the forums by the name of Lou rocked them on his car and he has the same suspension setup as us (stechs with tokico blues).
bolt on. no rub, no nothing.
it'll work, long story short.
Postby Mr_Chunkz » Sun Feb 17, 2008 11:53 pm
looks pretty clean....
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby ThatVietGuy » Sun Feb 17, 2008 11:58 pm
ThatVietGuy
Postby DatSRBoi » Mon Feb 18, 2008 12:00 am
I can care less about the rims....
I want that chick!!!
Postby Ivanhoe » Mon Feb 18, 2008 12:07 am
DatSRBoi wrote:I can care less about the rims....
I want the rims AND the chick!!!!
Ivanhoe
Postby woa_its_j3ff » Mon Feb 18, 2008 12:08 am
that chick ghosts the forums btw
Postby CASTRO » Mon Feb 18, 2008 1:20 am
i have is300 rims on my camry
CASTRO
Postby JavaJoe_2 » Mon Feb 18, 2008 5:51 am
I'm running a 5mm spacer on the rear. They did rub on my Tokico's, took the paint right off.
Got Boost?? :sweet:
JavaJoe_2
Postby CamryOnBronze » Mon Feb 18, 2008 6:18 am
^ I was going to say, isnt the offset pretty high on those? Im sure theyll fit or be close at least, but you really need to get the offset bro.
Postby akora12 » Mon Feb 18, 2008 6:42 am
The IS rims fit much like the gen. 2 wheels. You'll need a 5mm spacer in the rear.
Postby CASTRO » Mon Feb 18, 2008 9:02 am
i used to run 5mm spacers in the rear but the 15mm spacers are MUCH better
CASTRO
Postby akora12 » Mon Feb 18, 2008 10:06 am
^^^ I should have said 5mm minimum in the rear. A 5mm spacer gives you less than a fingers width between the tire and strut (assuming your using a 215 or less tire).
Postby SleeperSolara » Mon Feb 18, 2008 10:46 am
So 10MM spacer would be best if you're usin' 225 width tires??
I love the width of 225's on my DWP. :D
Postby akora12 » Mon Feb 18, 2008 11:14 am
SleeperSolara wrote:So 10MM spacer would be best if you're usin' 225 width tires??
I would say a 10mm or 15mm would work for 225's. I'm even thinking of upgrading to a 10mm spacer just to get the outside of the tire more flush with the wheel well.
BTW, sorry man for not getting you those pics. I took them and totally forgot to e-mail them to you. I'll make a note to send them this evening.
