SolaraGuy.com • View topic - Whiteline Front swaybar install help..
Postby LatinUSMC » Mon Feb 25, 2008 9:51 pm
so i looked and seached and nothing...
i installed my TRD RSB, w. no problems
but ive heard or read here that the Front Sway bar is much harder any tips? Tutorial?
LatinUSMC
Postby Got2XLR8 NYX » Mon Feb 25, 2008 10:10 pm
Got Confused by your post... did u need a tutorial?
http://www.solaraguy.com/viewtopic.php?t=15817
5Speed 2000 SC V6 @ 4.5PSI
Got2XLR8 NYX
Postby Akfahad » Tue Feb 26, 2008 6:36 am
I ended up having a shop install my FSB...good thing too, most of the nuts were seized up, but regardless, they had a pain installing it.
Postby TadS » Tue Feb 26, 2008 12:19 pm
It’s a real pain in the butt. My biggest tip would be don’t do it if you’re on a tight time budget. You also may end up needing to replace your front sway-bar links, so make sure that a local supplier has some in stock. Just take your time and it’s a very doable proposition.
TadS
Postby Akfahad » Tue Feb 26, 2008 3:05 pm
TadS wrote:You also may end up needing to replace your front sway-bar links, so make sure that a local supplier has some in stock.
^^Word, I ended up having to do that too.
Postby SleeperSolara » Tue Feb 26, 2008 3:28 pm
I want to know what those brackets are that would work wit the Whiteline Front Sway Bar.....
Postby LatinUSMC » Tue Feb 26, 2008 4:38 pm
thanks guys.. in comparizon to the RSB whats the difficulty facto? i may just have alocal shop do it... Or maybe ...Milton-R-Us.
Milt... where u @ Big Boy?
LatinUSMC
Postby TadS » Tue Feb 26, 2008 7:04 pm
LatinUSMC wrote:thanks guys.. in comparizon to the RSB whats the difficulty facto? i may just have alocal shop do it... Or maybe ...Milton-R-Us.
I would say that it probably 3 times as hard. It's more time consuming than anything. Trying to work the bar in is a pain, but I did it several years ago in the driveway, so I say go for it.
TadS
