SolaraGuy.com • View topic - ASC Sunroof Quick Fix & Info
Postby illstylez » Tue Feb 26, 2008 5:52 pm
ASC Sunroof
** See original post at:
http://www.solaraguy.com/viewtopic.php?t=38664
Ok so i found out the problem to my issue was the orange wire was disconnected from its location( as suspected ). I called the people at ASC and they were VERY helpful. The guy there told me that its pretty much a hack job that they plugged it into a "keyed power" or ignition only powered source. Usually he said they configure it into the ignition relay.
I just went ahead and plugged it back into where I believe it came from which was the windshield wiper socket for that corresponding fuse.
This Sunroof was an after market install probably had done by the original owner either at the dealer or elsewhere. WHO KNOWS I bought it used. Considering the age of the car besides this issue I have had no problems with the sunroof thus far (i.e. leaking, or wind issues...knock on wood) There was also another place I have to give credit to helping me to via email which can be found here:
http://www.aslauto.com/sunroofs/asc.htm
The originators of the product are found here
http://www.americansunroof.com/
So if any one has this type installed here hopefully you can find some answers, or at least a lead(no pun intended)!
Kentel " Ill " Styles
Chicago IL,
99' Solara Since 2007
" The best way to predict the future is to create it! "
illstylez
