SolaraGuy.com • View topic - 17x7 45 offset wheel, need spacers???
Postby tboidsc » Fri Feb 29, 2008 11:06 am
Thinking of getting Enkei GTC01's for my 2000 Solara. I am sticking with the 17x7, but they only seem to come in +45 offset. If I am not mistaken, this means that the tire will be closer in towards the strut and may rub.
Has anyone had a similar experience? Did they have to purchase 5mm spacers. H&R tells me that I would need to change the lug studs as well, but do I really have to if all I am doing with the spacer is making the offset of the wheel +40, which are the Revo's on my car that I am replacing.
Wouldn't the 5mm spacers just bring the new wheels back to where the Revo's sit today, and no need for lug studs?
Here is a pick of the wheel in Hyper Black
I am replacing my Bridgestone S-03 Pole Position's with RE960AS Pole Position's.
Pick of my car today
2000 TRD Solara 5-sp DWP
1MZ-FZE engine
Supercharged, lots of extras
Renova front Grille
tboidsc
Postby ThatVietGuy » Fri Feb 29, 2008 11:10 am
I'm pretty sure it'll fit just fine.
ThatVietGuy
Postby tboidsc » Fri Feb 29, 2008 11:44 am
With out the 5mm spacers?
Or the lug studs will be long enough with the 5mm spacers.
Sorry I know I asked alot of questions in my post.
1MZ-FZE engine
Renova front Grille
tboidsc
Postby woa_its_j3ff » Fri Feb 29, 2008 11:46 am
It'll fit fine I think although the 5mm's may make is be a more 'flush' so to speak. nice wheels man. kind of remind me of the Enkei RSV's
Postby .onetohate » Fri Feb 29, 2008 12:01 pm
no you don't need them but they'd look hellah sunken in.
I have the same size with the same offset and i'm gonna put on some 10mm spacers when my extended wheel studs come in so it'll push the wheel out better.
.onetohate
Postby tboidsc » Fri Feb 29, 2008 12:56 pm
Yeah, they do look like the RSV's. Thanx.
OK, so if I get the 5mm spacers, it would push them back out to where my +40 Revo's are. I think that would be best, since I fear if I push them out too much, due to the lowering, I will rub the fender in the rear. I already had to roll up the fenders a little bit in the back with these. I have 225/45/17 tires.
1MZ-FZE engine
Renova front Grille
tboidsc
Postby CamryOnBronze » Fri Feb 29, 2008 2:09 pm
I just went with H&R spacers on the rear of my car- 5mm spacers with longer studs, theyre nice! then you dont have to worry about the length of your studs being too short either.
Postby akora12 » Fri Feb 29, 2008 2:39 pm
It will be tight in the rear, but it will fit unless you go with a really wide tire. It would definitely be nice to push them out a bit with a 5mm or 10mm spacer.
Postby 1gSE » Fri Feb 29, 2008 3:43 pm
mmm...the RSV's...i want them is bronze. That might just be my xmas present to myself
Solara-M62 @ 5.5psi
1gSE
Postby kwyse » Fri Feb 29, 2008 4:50 pm
My enkei's are 19x7 with a 45 offset and they dont rub at all. I'd prefer the rears out a little more, possibly 5mm or 10mm, but as of now no spacers.
Btw, very nice choice of rims.
kwyse
Postby tboidsc » Mon Mar 03, 2008 12:48 pm
CamryOnBronze wrote:I just went with H&R spacers on the rear of my car- 5mm spacers with longer studs, theyre nice! then you dont have to worry about the length of your studs being too short either.
Thanx for the info guys. Do you really think I need to extend the lug studs. If a +40 offset fits today, aren't I just adding more "meat" so to speak to the +45's to make them +40? Shouldn't it fit regardless? I can see if I added 10mm, then I may be looking at longer studs, right>?
1MZ-FZE engine
Renova front Grille
tboidsc
Postby Eye8Pussies » Mon Mar 03, 2008 1:22 pm
on the whole, 5mm spacers are usually fine without longer studs (I've ran 5mm spacers in my rear for my summers for years now)
but for 10mm spacers, longer studs are a definite
Postby Sebas007 » Sun Apr 06, 2008 8:56 am
If you verify H&R spacers...you'll note that the 5mm is way less cheaper than 10mm+ spacers...why ?? Because they include in a kit the longer stud and all you need to make it right.
As metioned in H&R website.
http://www.hrsprings.com/products/trak/
Note : only the DR series doesn't include longer studs.
Postby JavaJoe_2 » Sun Apr 06, 2008 9:10 am
My 5mm H&R's came with the longer studs, but I chose not to run them. I have 7 complete turns of the lugnut like their directions say is fine. I am running IS300's 17x7 with a +50 offset the tires are 215-50-17 which turns out to be back to stock as the factory rim/tire combo. I don't like to think am I going 5mph (or so) over/under.
Got Boost?? :sweet:
JavaJoe_2
Postby Sebas007 » Sun Apr 06, 2008 12:23 pm
Yeah you are right. 5mm include the studs... so I wonder why 10mm+ spacers are that expensive compare to 5mm
