SolaraGuy.com • View topic - Problems with hid
Problems with hid
Problems with hid
Postby prsolara » Fri Feb 29, 2008 4:51 pm
today i bought a hid conversion kit, not the ebay ones, and installed them in the shop but i am having problems with it. first the lights are like blinking, they said that it was the day lights (drl) that was giving this problem but i dont know, and second the light output is very low dont know why, i am like dissapointed of this:x, anyway if someone have a solution to it, will be very appreciated.... :(
thanks in advance
prsolara
Postby SolaraBlue » Fri Feb 29, 2008 5:15 pm
the blinking will happen with the drl's... just flash your high beams a couple times and theyll turn on fully...
as for the light output... they could be installed wrong... how many k's are they? 6000k, 8000k, etc...?
Postby prsolara » Fri Feb 29, 2008 5:27 pm
they was 8000k but i dont liked them and changed it to 10000k i know if more higher less the output but with the other ones also was giving the problem...
and what i have to do just flash the high beams only? cuz i already do this without solution... thanks bro for the reply
prsolara
Postby SolaraBlue » Fri Feb 29, 2008 5:40 pm
the bad output is due to the high k's... anything over 6000k is just for looks...
if the flash doesnt work, turn on your headlight and off and on and off and see if that works... is it both headlights blinking or just one? try switching the ballasts and see if that works... check connection as well...
Postby akora12 » Fri Feb 29, 2008 6:14 pm
Do you have a separate wire harness for the kit? DRL's run at a lower wattage which can cause problems with the ballast.
Postby prsolara » Fri Feb 29, 2008 6:15 pm
nop, i tried both, but no solution, tomorrow i will try to swith the ballast to see if is that, not know... :(
prsolara
Postby facevedo17 » Fri Feb 29, 2008 8:05 pm
hook up a fuse and set it so its getting powered directly from your battery that way when the drl are on its using the juice from the battery " set up an relay ....
facevedo17
Postby prsolara » Tue Mar 04, 2008 4:49 pm
hey guys, finally i got the hids working well, but they keep like flashing a little bit, and dont know where is the relay or fuse that i have to pop out so the drl lights will come off, any help? where is the location of this relay cuzz i put one out and the drl lights come off, but i can't put the lights on manually LoL :-? ...
any help will be appreciated
thanksssss!
prsolara
Postby SolaraBlue » Tue Mar 04, 2008 4:53 pm
theres a gray plug located on the passenger side of the engine compartment, unplug it. then unplug the little sensor on your dash. comes out easy.
Postby prsolara » Tue Mar 04, 2008 5:07 pm
sorry but where is the sensor in the dash in? which part??
and if i only unplug the gray plug in the compartment will work or no?
thanks bro for helping me
prsolara
Postby SolaraBlue » Tue Mar 04, 2008 5:57 pm
the sensor is that red nipple looking thing on the passenger side of the dash... youve never realized that thing was there? maybe you dont have one? either way, pop it out, unplug it. the gray plug might work by its self but its not 100% as long as the dash sensor is still plugged in.
Postby prsolara » Tue Mar 04, 2008 6:42 pm
:o i never realized that that thing was a sensor lol!!
thanks bro!!! for answer my questions!
prsolara
Postby xh0rnsb0yx » Wed Mar 05, 2008 12:31 pm
i used the DRL tutorial and i still couldnt get them disables. where is the gray plug again?
xh0rnsb0yx
Postby xh0rnsb0yx » Wed Mar 05, 2008 1:19 pm
NVM got it
xh0rnsb0yx
Postby xh0rnsb0yx » Wed Mar 05, 2008 3:18 pm
ok take that back it still doesnt work..where the hell is the gray plug
xh0rnsb0yx
