SolaraGuy.com • View topic - Radiator Cap Question
Postby TadS » Tue May 27, 2003 8:43 pm
I am going to order a higher PSI radiator cap today and I need to know which one I need for my car. I have the 5S-FE, so I think I need the Type-N. I just want to make sure though as it seems Toyota uses both the Type-S and Type-N depending on the application. Thanks in advance for the info guys.
TadS
Postby NASTY » Tue May 27, 2003 8:51 pm
im pretty sure type-s is for the 6
so by elimination, get the type-n
'01 SLE V6
NASTY
Postby Yanks0114 » Wed May 28, 2003 10:41 am
Either one will work, personally I would go with the lower PSI one (18PSI)
Postby TadS » Wed May 28, 2003 10:00 pm
Ok I am going to order the Type-N. It’s 1.3 bars I agree with you Yanks on going with only the mild increase. Anymore more would be overkill, and I would probably blow my hoses :P. Thanks for the information.
TadS
