SolaraGuy.com • View topic - SLE Climate Control Backlights?
Postby Mr_Chunkz » Tue Mar 04, 2008 11:27 pm
Im not sure if this has been posted
And to be honest I didnt bother searching cause I remember I did before a while ago and nothing turned up
I know HVAC in Solara SE uses.. 194 bulb ( i think ) from a tutorial I read a while back but does anyone know for sure what SLE climate control uses? I've been meaning to change out those bulbs in my car to match my blue/white LED thing I had going.
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby woa_its_j3ff » Tue Mar 04, 2008 11:49 pm
its not 194 dude, not if u have sle and auto climate. i asked this a few days ago, it's the kind thats soldered in, a #74 bulb I think it is? def not a 194 bulb. if it were that easy I woulda done it already ;)
Postby DrLove » Wed Mar 05, 2008 6:52 am
If it's the "manual" HVAC, it use 2 bulbs "74". If it's the auto HVAC, I don't know but I guess it's just like the radio. :)
Mazda 6 2010 6 speed black GS
DrLove
Postby 2kSoulara » Wed Mar 05, 2008 8:02 am
if anyone needs an auto HVAC i have one to sell. There is also a tutorial to change the lights in it..search.
2kSoulara
Postby Mr_Chunkz » Wed Mar 05, 2008 10:59 am
woa_its_j3ff wrote:its not 194 dude, not if u have sle and auto climate. i asked this a few days ago, it's the kind thats soldered in, a #74 bulb I think it is? def not a 194 bulb. if it were that easy I woulda done it already ;)
I dont believe 74 bulb requires soldering...
Can anyone shed some light on this?
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby Mr_Chunkz » Wed Mar 05, 2008 11:05 am
2kSoulara wrote:if anyone needs an auto HVAC i have one to sell. There is also a tutorial to change the lights in it..search.
i did
it pulled up the same tutorial i used to replace all my interior bulbs
however
that one has instructions how to replace HVAC, not Climate Control bulbs. Us SLE Guys have that damn green climate control screen.
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby NeFaRiOuS_SLE » Thu Mar 06, 2008 5:35 pm
There's 6-7 #74 light bulbs, all of which look like:
http://autolumination.com/74.htm
Scroll halfway down and look for something labeled as a "Type B" (WARNING: I don't remember what diameter type you need exactly, just a reference point).
Postby woa_its_j3ff » Thu Mar 06, 2008 5:40 pm
i did
however
hey Tracy, pull out the climate control, let me know if it's just a pull and plug in bulb, or if it's actualy one needed to solder or w/e in. if it's just a simple bulb replacement, then switchin the color shouldn't be hard at all.
Postby NeFaRiOuS_SLE » Thu Mar 06, 2008 7:03 pm
^^Read my post.
It's a #74 bulb attached to a base that you rotate 90 degrees to pull out and put back in. No soldering required. I've replaced a burnt out bulb in my climate before.
Postby woa_its_j3ff » Thu Mar 06, 2008 8:21 pm
sweet, are the bulbs stock green? or do they have caps over it? cuz if it's just a bulb I can make red .. then hell I'll look to do that next week!
what you mean diameter size??
all #74 bulbs should fit, no?
anyways I ordered the 10mm diameter one just to be the safe.
Postby Solorange » Fri Mar 07, 2008 11:40 pm
If you guys want to do it cheap just pull the green condoms off the bulbs and color them with a sharpie. I did this and had no color fade. Its been like this for 1.5-2 years now.
Postby woa_its_j3ff » Fri Mar 07, 2008 11:42 pm
Solorange wrote:If you guys want to do it cheap just pull the green condoms off the bulbs and color them with a sharpie. I did this and had no color fade. Its been like this for 1.5-2 years now.
yeah but you dont have auto climate!!! you might have diff setup.. hope not.!!! lol ill update this thread in a week or so. since my bulbs are on the way, unless if tracey tackles this thing before i do.
Postby Solorange » Fri Mar 07, 2008 11:56 pm
[[/img]
Oh my bad I miss read Chunkz's post. Either way for all you manual hvac guys its easy. By the way isn't the digital hvac unit for the SLE have leds??? If so you will have to do what I did for the radio.
Postby DrLove » Sat Mar 08, 2008 11:58 am
Before I was using a blue transparent plastic, remove the green condoms for the manual HVAC. It was looking good, but it's not like LEDs.
For the auto HVAC, I would use 74 LED or color bulbs, not a color plastic or shapie.
But it's just my idea, all depend what kind of theme you want to do,
I think you need to think about a theme or do a plan of what you want before to start messing there.
Some people want to match color with the aftermarket radio they bought, etc, some wants to match the gauges, some want all blue,red,orange...
Don't forget to change the clock color, leaving it "green" is very ugly.
The only way I know to change the clock is to put a color over it,
blue plastic=blue clock
red plastic =orange clock.
yellow plastic = ??
I could try to find a "indigo" display to solder the clock and make the clock more beautiful, but it would take lot of time searching for pieces,etc..don't worth for now spending my time on this, impact is so little.
DrLove
Postby Mr_Chunkz » Sat Mar 08, 2008 12:23 pm
I will be looking into this on monday
and after i poke around thoroughly
i will order bulbs.
- Mr_Chunkz -
The Daily
Mr_Chunkz
