SolaraGuy.com • View topic - WHEELS
WHEELS
WHEELS
Postby g00nsquaddd » Wed Mar 05, 2008 2:20 pm
my guys giving me his Z tires with 17' rims.
i think the tires size are 240.
do you guys think i should replace it?
mod note- post in the correct forums!
g00nsquaddd
Postby Sebas007 » Wed Mar 05, 2008 3:06 pm
Wow the wheel must be pretty wide to use 240mm wide tires...
I would bet it will not fit the lara no matter what offset you have for your wheels !! IMO...and at best it will be an extreme close call coming with a ton of tire rubbing worries.
Postby ThatVietGuy » Wed Mar 05, 2008 7:10 pm
350Z I presume?
If so, you might be fine if you're stock height. I used the 350Z 17s for a couple days back when I had stock suspension and everything seemed to be ok (although the tire setup was 225 front, 235 rear)
If you're lowered, you will rub like crazy.
ThatVietGuy
